8 Users Online (6 Members):
Forums >> Revit Structure >> Technical Support >> "tracing" a imported DWG
56 Posts No Rating |
I have an ackward structure that the Architect has drawn in AutoCAD, I have imported it and manged to cretate the beams using the select on a line command, I now wish to do the same with the columns, is there a way to do this? also just to add spice the columns are sloping..... which im also not sure how to draw, any help would be appreciated!
Revit won't be able to tell the lines are colums so you'll have to measure them individually and because they are sloping you'll need to create your own families. If you need more help then post a picture of what you are trying to create. John
allan, if the columns are drawn in 3d in autocad...just export out to ifc and then import via ifc...you might get the whole column...
I really want this to work...some good things some bad |
not to see imported dwg on every level (after importing dwg) |
Sun, Nov 26, 2006 at 11:13:58 PM
Imported image troubles, can I "pin" it? |
Wed, Nov 19, 2008 at 2:03:41 PM
Imported DWG visibility? |
Tue, Aug 7, 2007 at 10:07:42 AM
imported DWG visibility |
Fri, Apr 13, 2007 at 12:26:22 AM
importing dxf file |
Mon, Dec 15, 2008 at 6:38:24 AM
