Forums >> General Discussion >> Revit Project Management >> DOOR SCHEDULE
Thu, Jan 15, 2009 at 4:43:32 PM | DOOR SCHEDULE
jgmas
I created a custom door with sidelites. the door width and height shows on the door schedule fine but i don't know how to make the sidelite dimension show on the schedule as well. I created a sidelite parameter on the door and the door schedule but the dimension does not appear automatically, I have to enter myself by typing it.
Does anyone know how that works?
Thanks
Fri, Jan 16, 2009 at 11:15:24 AM | DOOR SCHEDULE
Thread Post Kudo! #2
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
Yes...
You must change your Sidelight Dimension(s) to be a "Shared parameter".
After you have changed this "Family parameter" to a "Shared parameter", save and load into your project.
Adding the parameter to the project file:
Go to Settings > Project Parameters... > Click "Add" > Check "Shared parameter" > Click "Select" > Select the appropriate "Parameter group" > Add your Sidelight Dimension(s) parameter (OK) > Select the "Door" category > Group the parameter under "Dimensions" either Instance or Type (your preference)
Adding the parameter to the Door Schedule:
Navigate to your Door Schedule Properties > Edit the "Fields" > You should now see your Sidelight Dimension(s) as an Avaiable field:> Add > DONE and DONE.
Using Shared Parameters are great for schedules *take it a step further and add parameters that indicate all desired Headings within your Door Schedule. First, add them in the family files, then load them into your project file or project tempelates, you will drastically reduce your time of having to fill in the schedule cells, one-by-one. However, in doing this, make sure that you designate which parameters should be "Instance" or "Type" Smile
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Schedule material mark in door schedule - Revit 2014
Fri, Jan 19, 2018 at 2:57:03 PM
Door Schedule
Fri, Aug 17, 2012 at 7:07:50 AM
Customized Door Schedule Needs Help
Thu, Aug 25, 2011 at 5:53:09 PM
Trying to Schedule a door that lives in a Window Family
Thu, Jan 16, 2014 at 12:07:10 PM
Manipulating the door schedule
Wed, Jun 26, 2013 at 10:35:33 PM
11
Page generation time: 0.3262
