62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> massing
i create a mass extrusion fromthe level one plane and finishmass and look at it in 3D andall other views fine.. i create the same extrution froma vertical plane i created bydrawing the sketch from asouth elevation and it looks fine and then finish the massand it shows in NO OTHER VIEWS? i start a new project and createa mass on several planes and theyALL show up in ALL VIEWS.. what is causing my mass to notshow up anywhere other than theline sketch on the plane?
Go to that view and check in VG if the "Mass" box is turn ON like in the image attached...
thanks for trying to help me.. vg/mass is the first thing i turned on.. i can open a new project and create a vertical work plane and extrude off of that in an elevation view and then look at the new mass object in all views.. but something must have changed in my project because when i finish mass on a vertical work plan the sketch lines for the extrusion stay there in that one view but i can't see it in any other view.. i don't get it..
Can you please put some images to figured it out?
why my massing can't not be a solid? |
Fri, Feb 11, 2011 at 8:26:42 PM
Massing |
Mon, Jun 22, 2009 at 9:18:46 AM
conceptual massing...undulating roof shape |
Thu, Jun 24, 2010 at 3:01:55 PM
Finding Massing Model |
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP! |
Fri, Nov 6, 2009 at 4:07:53 PM
Members: | 1994489 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
