69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> recepticle with two circuits how do I tag both? help!!
Thu, Dec 4, 2008 at 11:13:37 AM | recepticle with two circuits how do I tag both? help!!
paulykustomz
paulykustomz Avatar
have created a counter receptacle (electric) with two power connectors (because each outlet is on a separate circuit). I can hook it up fine.
however, when I tag it I can't find how to display both circuits in the tag, or at least tag each circuit separately (still on the receptacle)
Thu, Dec 4, 2008 at 11:34:51 AM | recepticle with two circuits how do I tag both? help!!
paulykustomz
paulykustomz Avatar
basically I have outlet plugs in a kitchen where the top plug is on one circuit and the bottom one is on another circuit. when I go to label the I cant
Mon, Sep 28, 2009 at 2:12:42 PM | recepticle with two circuits how do I tag both? help!!
MARS1276
1 Stars: 1 Votes
Don't know if this will help much or not, but a lot of times if I copy/paste an element on top of another element of the same... I get a message saying that this may reflect the wrong count in scheduling resulting in a double count.
You might try Copy to Clipboard/paste in same place... see if that allows you to tag and schedule both
Multi-wire homerun tag out of order
Fri, Dec 9, 2011 at 10:18:57 AM
Revit Architecture 2013 Electrical Circuits
Thu, Jul 11, 2013 at 7:27:01 AM
Is there a way to show switch circuits in Revit MEP 2011
Thu, Mar 17, 2011 at 5:17:45 PM
One light fixture, two circuits?
Mon, Jul 14, 2008 at 9:18:24 AM
Electrical Circuits - odd and even number
Wed, Sep 22, 2010 at 1:16:55 PM
Page generation time: 3.0521
