Forums >> Revit Building >> Technical Support >> Linked revit drawings and Topo surfaces.
Thu, Nov 27, 2008 at 10:41:54 PM | Linked revit drawings and Topo surfaces.
eltazar
Im using revit 2009 and drawing a small development with multiple residence and in which i am using a site drawing and then linking each seperate residence drawing into that file.
When i link the drawings and display the topo surface of the site in the reisdence plans the elevation of the surface is not correct in relation to the residence floor level. Is there a way that the topo surface will link through at the correct elevation so that my ground plane is correct in each residence file?
 Thanks for your help.
Rendered materials on topo surfaces
Thu, Jun 15, 2006 at 8:46:47 AM
Topo surfaces on top of structures
Sun, May 4, 2008 at 4:59:38 AM
Revit 2011: Linked model not displaying casting shadows
Tue, Sep 28, 2010 at 1:55:13 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Topo joins/merges
Thu, Sep 13, 2012 at 1:21:56 PM
Page generation time: 3.4780
