Forums >> Community >> Newbies >> Need help with Nested Objects
Wed, Nov 26, 2008 at 11:17:10 AM | Need help with Nested Objects
MARS1276
1 Stars: 1 Votes
I have tried this and had much trouble doing so.  What I want to do is create a family of doors (simple) and a family of door hardware (simple) and have those two work together in a drawing titled 'DOORS'.  This I managed to do; my goal here being able to make different combinations of doors with hardware.  This works fine in the 'DOORS' file, but when I am in a template drawing I want to add those families so they will work in our standard default template as well.  This way when we start a project we will aready have them loaded and ready to go.
I have been able to bring in the 'DOORS' family in our default template file, but it didn't work so well.  I had created different family styles for each combination of door with hardware (for a total of 36 styles).  When I place the door within a wall, I could select the door style and change the panel, but the hardware would not change.  The same hardware shows on my door regardless of which style I chose to change the door to.
For now I have opted to simply draw the imagery of the hardware as a simple 2D design on the door panel itself.  But what I really want to do is what I mentioned above.  Can someone please help?  I tried posting this once earlier today with the files attached so they could be dissected, but then my message didn't even post.  If anyone can help and needs the file, I would be willing to e-mail it instead of trying to post it again.
Thanks in advance!
Mars
array of nested objects
Tue, Oct 14, 2014 at 2:27:27 PM
Tagging Nested Families
Wed, Apr 8, 2015 at 3:13:34 PM
Nested Void Problems on Shared Families (doesnt cut nested family if its shared)
Tue, May 10, 2016 at 8:39:49 AM
Array in Revit families in shocking!!!
Mon, Jan 23, 2012 at 9:33:10 AM
Nested Family referencing Host family
Fri, May 10, 2013 at 7:15:14 AM
Page generation time: 3.1717
