Forums >> Revit Building >> Technical Support >> Dimensioning in Imperial & Metric
Mon, May 16, 2005 at 6:55:07 PM | Dimensioning in Imperial & Metric
thelostboy
My firm is working on a GSA project. Part of GSA standards is the appearance of Imperial and Metric dimensions. Presently, some poor intern is going to get to spend 6months manually adding the metric equivalent to existing dimensions. I am wondering if anyone could tell me how to create a dim-type that would simultaneously show both and thereby save the sanity of the yet unnamed intern. Much thanks.
Tue, May 17, 2005 at 12:43:52 AM | RE: Dimensioning in Imperial & Metric
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You cannot have a dimension showing both imperial and metric dimensions simultaneously. You can however have one dimension style to show imperial and another dimension style to show metric. Just simply duplicate the dimension style and override the project units in the dimension settings to the appropriate imperial or metric setting. HTH.
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
Metric Viewport in an Imperial Unist based project
Mon, Aug 11, 2008 at 9:16:58 AM
Imperial metric question RAC2009
Fri, Jan 9, 2009 at 11:35:51 AM
Imperial to Metric
Fri, Aug 8, 2008 at 4:11:17 PM
Page generation time: 0.3445
