Forums >> Revit Building >> Technical Support >> Dimension font changes when exported to Autocadd
Fri, Nov 14, 2008 at 1:44:41 PM | Dimension font changes when exported to Autocadd
johnalgeo
We are working with Revit 2009 and exporting to Autocadd 2007.
 The dimension font is ARchitxt in Revit; however Autocadd turns it into "Standard" text.  All other texts, tags etc remain ARchitxt.  I export with "no overrides" to keep the text "bylayer and bycolor"  Please, no debate on why we use ARchitxt.  It's a legacy.
 Thanks in advance,
JSA
john a
Fri, Nov 14, 2008 at 2:45:31 PM | Dimension font changes when exported to Autocadd
Sounds like you will have to open your autocad files and change it back.
Tue, Dec 23, 2008 at 1:11:24 PM | Dimension font changes when exported to Autocadd
johnalgeo
Can we set the dwg default text to archtxt as the standard text?
john a
Tue, Dec 23, 2008 at 6:14:43 PM | Dimension font changes when exported to Autocadd
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Revit and Autocad use two different types of font.
Revit = True Type Font (architxt.tff)
Autocad = Shape Font (architxt.shx)
You'll probably notice Revit does not export text quite to the right scale either.
Edited on: Tue, Dec 23, 2008 at 6:15:49 PM
Dimension
Tue, Apr 15, 2008 at 3:30:03 PM
Listening dimension display too small
Sun, Jan 31, 2010 at 6:43:41 AM
Dimension String Question
Wed, Feb 27, 2013 at 12:17:25 PM
Font issue?
Tue, Feb 13, 2007 at 3:11:45 PM
Why I cant change Dimension fonts?
Thu, Aug 10, 2017 at 11:51:39 AM
Page generation time: 1.8652
