Forums >> Revit Building >> Technical Support >> tilted walls
Mon, May 16, 2005 at 9:06:48 AM | tilted walls
Rugrat
Does anyone know how to do a wall that is not 90 degrees from the floor? Is this just a s simple as creating a new wall type or this a more difficult process?
Mon, May 16, 2005 at 12:16:10 PM | RE: tilted walls
TomDorner
4.5 Stars: 25 Votes
I would do it as an in-place family using a sweep to get the wall profile and slope. HTH Tom
Mon, May 16, 2005 at 12:27:47 PM | RE: tilted walls
Rugrat
that makes sense. I guess i would just use voids for my openings and piece walls in those openings so i can insert doors and windows. Does that sound about right?
Mon, May 16, 2005 at 2:04:18 PM | RE: tilted walls
TomDorner
4.5 Stars: 25 Votes
You can place door and windows into the sloped wall (use 3D view), but it will probably not behave like you would expect. Best advice I can give is model it like you would build it the best you can using the present set of Revit tools. Tom
How to make a tilted roof
Mon, Mar 14, 2011 at 3:36:00 PM
TILTED curtain walls
Sun, Jul 1, 2007 at 4:26:50 AM
tilted, slanted or tapered walls
Wed, Dec 3, 2014 at 7:32:27 AM
tilted slab edge !!!
Fri, Jul 26, 2013 at 8:31:06 AM
Building PADs - Tilted walls
Fri, Jun 15, 2012 at 12:50:09 AM
Page generation time: 2.5686
