7 Users Online (5 Members):
Forums >> Revit Structure >> Technical Support >> Section Cut
8 Posts No Rating |
Does anyone have the standard Section Cut that comes with Revit modified to allow for the Reference Text to be placed in any of the four corners? I want to be able to select which corner I want the text to show up in. If not can someone show me how to do that.
I do not think you can do that. You can turn off the sim and place your own text.
8 Posts No Rating |
Thats whats been done before but when you have a ton of them on 1 sheet it would easier to just update the family type and then be able to select which ones had which part turned on. Such as TopRight, TopLeft, BotRight, and BotLeft.
Cut Pattern in Plan vs Section |
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets |
Fri, Jun 27, 2008 at 12:33:38 PM
Is it possible to not have the bold section cut lines |
Thu, Apr 3, 2008 at 12:58:16 PM
Segmented section cut |
Wed, Oct 10, 2007 at 1:19:40 PM
Animate section cut? |
Sat, May 29, 2010 at 5:15:48 AM
