461 Users Online (30 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Creating an Alternate Floor Plan(Revit 2009)
Tue, Oct 21, 2008 at 6:18:38 PM | Creating an Alternate Floor Plan(Revit 2009)
#16
TABEST
4 Stars: 4 Votes
DESIGNING A HOSPITAL ALSO, WE HAVE SEVERAL ALTERNATES, INCLUDING SHELLED SPACES, DIFFERENT USE AREAS, AND WHETHER OR NOT THEY WILL INCLUDE THE HELIPAD WE HAVE DESIGNED IN THE BASE BID.  USED DESIGN OPTIONS FOR THESE, BUT AS WWHUB SAID, THEY ARE TRICKY AT FIRST.  I FOLLOW THESE STEPS:
A) WHEN YOU WANT TO ADD SOMETHING TO A DESIGN OPTION: IF THAT SOMETHING EXISTS, THEN YOU CAN CLICK ON THE LITTLE "+" BUTTON ON THE DESIGN OPTIONS MENU BAR AND ADD IT THAT WAY, IF IT DOESN'T EXIST YET, THEN EDIT THE DESIGN OPTION YOU WANT TO ADD THE OBJECT TO.
B) RULES FOR DESIGN OPTIONS:  IF AN OBJECT IS GOING TO BE IN A DESIGN OPTION, AND IT IS A HOSTED OBJECT, THEN IT'S HOST ALSO NEEDS TO BE ADDED TO THE DESIGN OPTION.  THIS CAUSES A LOT OF "DOUBLE" WORK AS IF YOU WANT A DOOR IN ONE OPTION, BUT NOT IN ANOTHER, YOU HAVE TO DUPLICATE THE WALL, BECAUSE THE DOOR HOSTS IN THE WALL...
C) I WAIT UNTIL MOST OF THE ANNOTATING AND DETAILING IS DONE ON THE BASE BIDS, THEN I JUST DUPLICATE THOSE VIEWS WITH DETAILING.  GO TO THE NEW COPIED VIEW, RENAME IT, AND IN VIEW PROPERTIES, CHANGE WHAT OPTION IS VISIBLE IN THE VIEW TO THE ALTERNATE BID THAT YOU WANT TO  SEE.
LAST AND FINALY, BE CAREFUL!  ONCE SOMETHING IS PLACED IN A DESIGN OPTION, IT IS
STUCK IN THAT DESIGN OPTION (UNLESS SOMEONE ELSE KNOWS BETTER?).  TO REMOVE FROM A DESIGN OPTION:  EDIT THAT DESIGN OPTION, CTRL+C (COPY TO CLIPBOARD) THE ELEMENT, THEN DELETE IT.  EXIT THE DESIGN OPTION, GO TO THE OPTION WHERE YOU WANT THE ELEMENT TO BE RESTORED TO, THEN PASTE IN SAME PLACE. (YES, THIS LOSES ANY DIMENSIONS, OR ANNOTATIONS ASSOCIATED WITH THE OBJECT IN ANY AND ALL VIEWS IN WHICH IT WAS ANNOTATED, THUS WHY I SAY BE CAREFUL).
ONE LAST THING, BUILD A TESTFILE, PLAY AROUND WITH DESIGN OPTIONS A BIT, TRY TO DUPLICATE WHAT IT IS THAT YOU WANT ACCOMPLISHED, ON A SMALL SCALE TO ENSURE YOUR UNDERSTANDING, AND THAT IT ACCOMPLISHES WHAT YOU WANT.
BEST OF LUCK  ACTUALLY...
Wed, Oct 22, 2008 at 7:22:49 AM | Creating an Alternate Floor Plan(Revit 2009)
#17
jcallis
Thanks for the help TABEST. And thanks to all of you guys for the help.
Wed, Oct 22, 2008 at 12:03:14 PM | Creating an Alternate Floor Plan(Revit 2009)
#18
Dgodfrey
4 Stars: 4 Votes
Activate the DO, then cut the wall. Get out of the DO and paste/aligned, current view in the main model.
Revit TotD – 7.31.09: Legend Tagging
Fri, Jul 31, 2009 at 8:08:39 AM
Creating Families
Wed, Sep 24, 2008 at 5:06:16 PM
Revit TotD – 10.12.09: Revit’s “Center” Command
Mon, Oct 12, 2009 at 10:56:00 AM
Using Revit for multi-level alternate
Tue, Apr 29, 2014 at 11:16:33 AM
Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
Thu, Jul 9, 2009 at 2:20:36 PM
Page generation time: 1.6016
