Forums >> General Discussion >> Revit Project Management >> Import Lineweights from CAD
Thu, Oct 2, 2008 at 5:51:11 PM | Import Lineweights from CAD
jchan
I am trying to import line weight settings from CAD into Revit so that when I import Cad files, they print out correctly.
In Cad, for example, Color 1 (RED)’s lineweight is 0.2540 mm.
However, in Revit, it assigns Pen weights, not line weights. How do I figure out what the pen weight assigned for each line weight? Any help is much appreciated.
Thank you
Fri, Oct 3, 2008 at 6:47:11 AM | Import Lineweights from CAD
Please learn to use REVIT's help - answers to questions like this can be easily found there.  Use simple one word searches are the best.  In this case "import" will result in a listing of topics including "Setting Line Weights for Imported DWG or DXF Files" ....
(2015) import (link) CAD to Revit screened lines (lineweights)
Wed, Sep 30, 2015 at 2:20:54 PM
Linked Cad File - Lineweights
Tue, Nov 18, 2014 at 10:20:58 PM
Lineweights from CAD to Revit
Thu, Aug 14, 2008 at 7:56:01 PM
imported dwg lineweights, linetypes
Fri, Aug 10, 2007 at 9:22:53 AM
import lineweights
Wed, Apr 30, 2008 at 9:21:35 AM
Page generation time: 0.9308
