Forums >> Revit Building >> Technical Support >> Help - stairs with arch run
Wed, Aug 20, 2008 at 11:42:57 AM | Help - stairs with arch run
herb05gcs
I'm trying to do a stair run that starts out straight than arches and then straightens out again. The problem I'm having is that the stringers don't form correctly or enclose the treds and risers correctly. I also can't figure out how to get the handrails to form and rise correctly. I've attached a revit file of the stair I'm working on with everything else purged from the file. Could some one please explain to me how this could be done with better results.
Oh, FYI I'm using Revit Architecture 2009
Thanks
Wed, Aug 20, 2008 at 2:20:34 PM | Help - stairs with arch run
4 Stars: 205 Votes
Hi, see the model....
Wed, Aug 20, 2008 at 4:25:38 PM | Help - stairs with arch run
herb05gcs
It looks like you fixed the problem with the stringers, but the inner rail is still warpped. Thanks for the assistance.
Can anyone help with the rail issue?
Thu, Aug 21, 2008 at 3:56:40 AM | Help - stairs with arch run
4 Stars: 205 Votes
Sorry for the Rail, i forgot about that, delete the interior rail and create a new one "By Host" in the stair...
Thu, Aug 21, 2008 at 11:39:20 AM | Help - stairs with arch run
herb05gcs
I tried that It is still giving me the same problem. Maybe the interior radius is just too small for the rail to rise correctly as it makes that sharp of a turn.
Thu, Aug 21, 2008 at 12:40:41 PM | Help - stairs with arch run
4 Stars: 205 Votes
Herb, do you search here in the Forum about the "Stairs", i don't remember when or who post a thread with this issue and several guys given several "resolution" to that, try to find out and when i have time (today) i gonna check again your model and see what's hapend...
Thu, Aug 21, 2008 at 1:17:09 PM | Help - stairs with arch run
4 Stars: 205 Votes
Hi, pick in the Rail and pick "edit" then in left menu "Design Bar" pick in "Edit Joins", then go to the intersections and pick, in the top menu you have a button "RAIL JOIN:" in there you can select the type of join you want in each segment, and you select another inters. and repeat the process until you have the shape you want, but in this case i think the arc (angle) is too small and give problems, try it... other way is delete that segment and create in place.....
Thu, Aug 21, 2008 at 2:54:22 PM | Help - stairs with arch run
4 Stars: 205 Votes
Hi check this also: http://revitoped.blogspot.com/2008/08/wishlist-top-five-august-19-2008.html
and this:  http://autodesk-revit.blogspot.com/2008/08/more-concrete-balusters-and-railings.html
Fri, Aug 22, 2008 at 8:17:04 AM | Help - stairs with arch run
herb05gcs
Thanks!!!
Fri, Aug 22, 2008 at 8:26:28 AM | Help - stairs with arch run
4 Stars: 205 Votes
You Welcome...
Triple Run Stairs 2008
Tue, Jul 24, 2007 at 9:03:44 AM
stairs! stairs! STAIRS! help!
Fri, Mar 20, 2009 at 4:34:04 PM
3 run stair case w/ 2 landings
Tue, Apr 3, 2012 at 2:44:18 PM
13
Assembled Stairs - Joining stringers from one set to the landings of another
Thu, Mar 13, 2014 at 3:13:48 AM
Help with stringers with landing
Wed, Jul 30, 2014 at 3:50:55 PM
Page generation time: 0.6560
