62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> Revision Clouds
2 Posts No Rating |
Can you add a revision cloud without linking it to a revision I just want to cloud something but not add a new revision. (Using Revbit Architecture 200
2 Posts No Rating |
2008
Im not sure what you have intended for this, but a work around that i found is you can copy the pink lines you use to draw the revision cloud...either finish or quit the sketch and then just past them outside sketch mode and it will paste them as detail lines. As for actually having the revision clouds with no Revision I have not found a way to do this yet...I would recomend just using the copy past method.
Revision Clouds |
Tue, Dec 18, 2007 at 10:52:44 AM
Revision clouds - off on one sheet but not on other sheets - is this possible? |
Fri, Mar 16, 2012 at 9:13:39 PM
shading revision clouds Revit 2017 |
Wed, Feb 28, 2018 at 2:56:28 PM
Revit clouds |
Tue, Jul 29, 2014 at 10:43:12 AM
Revsions & Revision Clouds |
Wed, Feb 20, 2013 at 1:32:13 PM
Members: | 2000495 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
