Forums >> Revit Building >> Technical Support >> Forumlas and Families
Thu, Aug 7, 2008 at 10:04:12 AM | Forumlas and Families
paunghe
I'm trying to write a formula that will allow me to have two 'Yes/No' items but one permanatly off for a given family.
Maybe I've got too much geometry in one family, but I was trying to keep it as one file rather than save it out as two seperate ones.
It seems that Revit's formula capabilities are a little lacking.  Also, there's no documentation on it except very basic that doesn't seem to help much.
Thanks
Thu, Aug 7, 2008 at 1:31:19 PM | Forumlas and Families
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I am not 1005 sure what you are trying to say, but you can add as many Yes/No parameters as you want. Or at least more than one i know that. Once you have an understanding of the revit syntax and mix that with advanced mathematics you can achieve quite advanced families. There is a .chm file you can download from Autodesk that helps with families, I have never used it personally but I know it exists.
Thu, Aug 7, 2008 at 2:20:16 PM | Forumlas and Families
I looked on the AutoDESK site for chm files & REVIT - found about 10 for Structure but none for Architecture.
Thu, Aug 7, 2008 at 2:30:51 PM | Forumlas and Families
alabaster2513
3.5 Stars: 25 Votes
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11091739
It's near the bottom of this page
Fri, Aug 8, 2008 at 5:13:26 AM | Forumlas and Families
Elmo
3.5 Stars: 4 Votes
In the formula box for the family that you want to have off at the time say not(parameter) and it will be off until you tick the other one off.
Fri, Aug 8, 2008 at 6:10:36 AM | Forumlas and Families
Thanks alabaster for the link ... I don't understand why it would not come up when I serached for it.
Fri, Aug 8, 2008 at 12:14:00 PM | Forumlas and Families
alabaster2513
3.5 Stars: 25 Votes
I seem to have that issue alot with using Autodesk's website. I find it easier to just use google for searching their sites.
Schedules and formulas
Thu, Jul 31, 2008 at 10:06:25 AM
10 New REVIT 8.1 'Families' Video Tutorials released
Tue, Oct 2, 2007 at 12:39:43 PM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Revit Families
Fri, May 24, 2013 at 4:23:33 PM
12
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
Page generation time: 2.1020
