Forums >> Revit Building >> Technical Support >> Base Cabinets, stretching and adding doors
Tue, Jul 29, 2008 at 7:25:00 PM | Base Cabinets, stretching and adding doors
StevenTrama
To Tech Support
Question, Can I make a base cabinet that when stetched (wider) new doors are added so my camera view of the base cabinet does not have one over sized too wide door but has two or more doors depending on how wide the base cabinet was made?
Question, Can I have a cost per linear (per object type) meter calculated, eg if I model fascia at 10 linear metres at a cost of $10 per metre can I get the schedule to calculate and display in a column the total cost of $100?
Tue, Jul 29, 2008 at 7:55:42 PM | Base Cabinets, stretching and adding doors
mhans
3 Stars: 10 Votes
Hi,
 What you are asking is doable. But it needs time from you to nest families and assign parameters. If you see a downloadable family here in Revitcity that says "parametric" model that means it has the capability to add/subtract elemets from its main family. Like a door that you are trying to have. See the Storefront Wall family to get the idea. Revit can do calculations in your schedules, you just have to have knowledge on how to use the operands and how they are organized. It's not that hard just follow some rules and it's even in the Help Menu.
Motto: "No Post left behind"
Number of doors depending on length...
Tue, Jan 17, 2006 at 11:42:37 AM
Cutting through a family in project
Mon, Dec 29, 2014 at 2:32:02 PM
Creating parametric (array) cabinets
Thu, Feb 14, 2013 at 1:26:47 PM
Cabinets only are inserting dashed
Tue, Oct 26, 2010 at 10:25:29 AM
Adding wall base
Thu, Aug 31, 2006 at 10:44:34 AM
Page generation time: 0.8630
