Forums >> Revit Structure >> Technical Support >> SLOPPED FLOOR
Tue, Jul 22, 2008 at 11:54:30 PM | SLOPPED FLOOR
fifthtexas
Hi
can anyone tell me the best way to produce a slopped floor, have a building with a basement that has a slopped floor. ground and first normal but basement is slopped,on a gradient. what would be best way to produce building.
2 floors as normal 90 degree perpidicular, basement different on gradient.
regards
fifthtexas
england
Wed, Jul 23, 2008 at 8:22:57 AM | SLOPPED FLOOR
KingRevit
4 Stars: 12 Votes
see your duplicate post
 also a bit of advice if your using revit building don't post to structure as there are many differences and it will just confuse u.
Wed, Jul 23, 2008 at 11:37:08 AM | SLOPPED FLOOR
AlexDring
1 Stars: 1 Votes
USE THE SLOPE ARROW, PUT IN YOUR FLOOR AND THEN EDIT IT AND CLICK ON THE ARROW ITSELF.  YOU CAN EDIT THE SLOPE THERE AND OTHER THINGS.
Wed, Jul 23, 2008 at 12:04:00 PM | SLOPPED FLOOR
JustinT
Yup the Slope Arrow in the Floor sketch will give you a single slope.. but you can also use the Modify Sub Elements on the slab (adding points and split lines which you can set the height to individually) is you want it sloping in several ways..
 http://www.revitup.co.za/_mgxroot/page_10801.php
Justin
www.revitup.co.za
Wed, Jul 23, 2008 at 12:06:36 PM | SLOPPED FLOOR
AlexDring
1 Stars: 1 Votes
interesting, never thought about doing it like it says above.
gradient basement floor ( on a slope)
Wed, Jul 23, 2008 at 8:18:55 AM
SLOPPED BEAMS
Thu, Jan 16, 2014 at 1:00:32 PM
slopped pad
Fri, Jun 23, 2006 at 9:42:32 AM
Roof condition
Thu, Jan 14, 2010 at 12:37:17 PM
create-parts and multi-layered roofs with shape edits
Sun, Feb 21, 2016 at 9:27:04 AM
Page generation time: 2.1897
