Forums >> Revit Building >> Technical Support >> Carrying over line weights in title blocks in RS 2008
Fri, Jul 18, 2008 at 3:32:14 AM | Carrying over line weights in title blocks in RS 2008
JamieH2304
I've recently started at a new firm where Revit has just been purchased.  I am putting title sheets together which are working inteligently, my problem being though is when I load into a project.
I have selected medium line thickness for the borders.  This remains in the title sheet file itself, but when I load into a project, all lines appear thin.
I can't figure out why.  Any ideds guys?
Many Thanks,
Jamie
Jamie Hunter
Walsh CE
Graphical House,
2 Wharf Street,
The Calls,
LEEDS.
LS2 7EQ
U.K.
www.walshgroup.eu.com
Fri, Jul 18, 2008 at 3:44:32 AM | Carrying over line weights in title blocks in RS 2008
jarrydmurray
2 Stars: 2 Votes
the line style (found under settings) has a different line weight in the project than in the title sheet family ie: medium line. when you load it into your project the projects setting is used, i suggest creating a new line style in the title sheet, editing its line weight and loading it into your project.
Delete or Purge out Title Blocks?
Wed, Nov 26, 2008 at 5:06:00 PM
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
Imported AutoCAD 2006 title block line thickness
Thu, Sep 7, 2006 at 3:27:44 PM
Revit Structure Questions Line Weights
Wed, Jan 16, 2013 at 3:33:32 PM
Customize new Title Blocks
Mon, Sep 21, 2009 at 2:55:19 PM
Page generation time: 0.4132
