Forums >> Revit Building >> Technical Support >> handrail that don't join on a stairs.
Thu, Jul 17, 2008 at 9:41:08 AM | handrail that don't join on a stairs.
KingRevit
4 Stars: 12 Votes
this was part of a post i had somewhere else but made a new one so its easier to find if anyone else gets this problem
ok so i got this to work, well sort of. the image looks right and it is well within tolerance but i wish revit was able to do semi automated. i will explain what i mean after i go through how to solve this incase anyone else has the same problem.
select your habndrail
edit
select the rail that isn't meeting the rest
on the options bar select height correction
and place in a figure
finish sketch
you will have to do this a few times untill you get (guess0 the correct height adjustment.
now this is where i wish revit had an option to automatically fix the the height adjustment.
Sun, Sep 21, 2008 at 9:04:56 AM | handrail that don't join on a stairs.
4 Stars: 205 Votes
Me too, i hope in the next version KING...
handrail balusters don't show up on stairs
Thu, Jul 17, 2008 at 11:16:32 AM
Handrail Supports on Multistory Stairs
Tue, Jun 24, 2014 at 3:10:16 PM
Handrail - Wall mounted
Fri, Apr 28, 2017 at 5:35:54 PM
Choppy Handrail / stringer joints
Wed, Mar 25, 2009 at 11:00:25 AM
STAIRS - Stringer & Handrail Cut
Mon, Nov 1, 2010 at 8:06:54 PM
Page generation time: 0.6283
