Forums >> Revit Building >> Technical Support >> R2009 - Labels
Wed, Jul 16, 2008 at 4:20:53 AM | R2009 - Labels
Sillybollox
In want to change the text which appears as " As Indicated" on the scale label in a sheet when you have varying scales of drawings. I have entered the sheet family and found the scale to be a lable but still no clue how to change the default text. Any ideas how??
Wed, Jul 16, 2008 at 9:39:28 AM | R2009 - Labels
broncos4life
3.5 Stars: 11 Votes
Click on the label, then at the top is "Edit Label" and in the box that opens you can change the sample value in there.
Sat, Nov 8, 2008 at 9:36:04 PM | R2009 - Labels
3ab8ari
As far as I know, from several attempts, this is not possible at this time !! Yes, believe it or not, that something this simple, is NOT possible. The text "As indicated" is fixed and hard wired. I have tried to change the family types using this conditional formatting for the Scale parameter line (but without any success): =IF (Scale = "As indicated", "AS NOTED", Scale) Let's hope they address this in the near future. As a general policy, we are using the simple rule of Out of the Box Revit. We try not to waste time manipulating what seems to be a Revit standard.....
Sat, Nov 8, 2008 at 11:27:30 PM | R2009 - Labels
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Why not create a shared parameter and call it something like "Different Scaling". Give it a visibilty parameter, and when you have views with different scales, hide "As Indicated" and show your "Different Scaling" parameter. Then you can change the text to whatever you want. If you don't need to change the text, just create generic text and apply the visibility parameter as mentioned above. Hope this helps.
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Sun, Nov 9, 2008 at 12:08:02 AM | R2009 - Labels
3ab8ari
Actually we had that idea presented too, but then the common thought was: NO! Let's keep it simple, and use it the way it comes out of the box.
host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 10:07:00 AM
Sky properties in r2009
Mon, Jan 12, 2009 at 11:23:25 PM
Title Labels
Sat, Jun 29, 2013 at 12:54:18 PM
14
View Labels and Bubbles are gone?
Mon, Jan 23, 2006 at 12:16:57 PM
MOVE GRID LABELS ON ONLY ONE DRAWING
Sat, Jul 12, 2014 at 1:56:41 PM
Page generation time: 0.0244
