8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Finished Floor Elevation Question
4 Posts No Rating |
Is there a way for me to specify that the main level finished floor level in my project is to read the actual finished floor number from the civil drawings? It automatically uses the default of 0'-0", and I want it to read as the actual elevation.
First you will need to select the Elevation marker and go to Properties-->Edit/New and change the Elevation Base value to Shared. You will now need to go to Tools-->Project Position/Orientation-->Relocate this project. You will then click outside an elevation view and drag the cursor up to the specified elevation. This procedure moves every thing in the project relative to the elevation.
finished floor on site plan |
Thu, Jul 26, 2007 at 5:13:49 PM
(Dumb question) Can't see first floor when in second floor view [Revit 2015] |
Thu, Jul 16, 2015 at 6:11:13 PM
BOP Tags for 2nd floor and above |
Thu, May 21, 2009 at 4:28:57 PM
How to have seperate floor finishes? |
Tue, Apr 12, 2011 at 7:12:38 AM
Newbie question on framing |
Tue, May 17, 2011 at 6:23:25 PM
