50 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to make a curved strip light
Tue, Jun 24, 2008 at 5:41:37 PM | How to make a curved strip light
MatthewLynch
Hi, I am trying to make a curved light that traces the edge of a balcony soffit - I have tried everything with no luck - can anyone please advise whether this is possible? Thank you.
Tue, Jun 24, 2008 at 7:55:51 PM | How to make a curved strip light
mhans
3 Stars: 10 Votes
Try in-place family from Modellling.."Create". Select Lighting Fixture as category. Use solid, sweep and define your path as the slab edge.
Motto: "No Post left behind"
Wed, Jun 25, 2008 at 7:12:18 AM | How to make a curved strip light
Whoa.... Are you trying to make a fixture that lights?  If so, I don't believe the in-place family will work.   With an in-place family, you could do a material that glows ... but that may not be enough.   Because lights that work are either a linear source or a point source, you may have to  model it like you would build it.  It would not be one light but a series of lights.
Wed, Jun 25, 2008 at 10:40:54 AM | How to make a curved strip light
MatthewLynch
Thanks so much for both replies. I have managed the glowing sweep and as you cannot copy multiple light sources within the same fixture a series of 'hidden' linear lights behind the sweep is probably the best bet I guess........
Lighting strip - how to make one?
Wed, Jun 15, 2011 at 7:06:06 AM
Light Fixture / Light Source - Wont Render with size change
Tue, Mar 24, 2015 at 11:35:15 PM
12
How to build a mobius strip in revit?
Mon, Aug 30, 2010 at 5:08:51 PM
trying to make custom light fixture w/ 2 light sources - need help
Mon, Jun 22, 2009 at 6:23:45 AM
Handrail Lighting LED Strip
Thu, Jan 11, 2018 at 6:31:21 AM
Page generation time: 0.4757
