67 Users Online (65 Members):
Forums >> Revit Building >> Technical Support >> From Revit Architecture 2008 to Revit Architecture 2009
18 Posts No Rating |
When i installed Revit 2008 last year its was a clean install and we had yet to start using revit. I have been usning revit for a year and have recieved the uprage to 2009 sometime ago and am going to install it. This will be my first time upgrading from a prevous revit version. Could you suggest the best workflow for upgrading and what has to be up graded? Familes? Teplates ? etc. Thanks for your help.
Well there are a few things that you need to consider but I'll list them as I go along. 1.You will need to upgrade all you family file so it wont give you the upgrade message everytime and waste you time in the future. Autodesk provides a program that will upgrade them for you which should be on your CD. 2.Your Template will need to be relooked at. The simple reason being that as there will be new versions and new feratures you can utilize it makes sense to relook at your template and your workflow just to make it that more simplified or find a different process since a tool has been changed. eg. Rendering. 3.You will need to make sure that your projects are upgraded correctly because revit will have some problems witht he upgrade process because of the new features. I suggest you do an Audit on the file just so that it keeps it clean in the long term. Hope this helps.
Thanks heaps. That helps.
Autocad Architecture join the Revit Architecture Suite |
Tue, Aug 19, 2008 at 9:14:55 AM
Revit 2009 Arch Struc User Guides/Tutorial Books pick up in LA |
Wed, Feb 10, 2016 at 7:28:35 AM
Vicozzio - New Revit Architecture User |
Wed, Sep 3, 2008 at 5:00:52 AM
Installation Of Revit Architecture 2009 |
Mon, May 5, 2008 at 1:59:54 AM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008 |
Tue, Nov 20, 2007 at 12:37:43 PM
