Forums >> Revit Building >> Technical Support >> CIP Landscape Stairs
Wed, Apr 6, 2005 at 6:37:01 PM | CIP Landscape Stairs
kfpopeye
I couldn't find any posts on this particular subject but it must have come up. I'm trying to create cast-in-place landscape stair. How can I get the topo to fit nicely under the stairs? You can't create a sloped pad as far as I can tell. I tried making a graded region but it regraded half my lot as well. Any ideas?
Life is one of those things that people find hard to avoid. - Rowan Atkinson
Wed, Apr 6, 2005 at 10:16:41 PM | RE: CIP Landscape Stairs
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I haven't had to do this before... But i'd either use a pad underneath then create an in-place family infil for the triangular section. Or just manually edit the topo points... We're not big users of the site tools.
Thu, Apr 7, 2005 at 12:35:34 PM | RE: CIP Landscape Stairs
kfpopeye
I find manually editing the topo points effects the grade levels beyond the stairs which can lead to undesirable effects. I just split the topo below the stairs and then adjusted the four corners to meet the underside of the monolithic stair. Loos good in section and rendered.
Revit for landscape and site design
Sat, May 29, 2010 at 11:54:15 AM
invisible road carparks and landscape on site plan
Fri, Aug 28, 2009 at 6:44:33 AM
create a family parameter to orient object to show either landscape or portrait
Wed, Aug 15, 2018 at 12:26:52 AM
landscape shown on ground floor
Mon, Jan 9, 2012 at 4:47:15 PM
Landscape Architecture and Revit - The future of
Fri, May 28, 2010 at 8:19:53 PM
Page generation time: 0.7828
