3 Users Online (1 Members):
Forums >> Revit Building >> Technical Support >> INTERIOR ELEVATIONS BOUNDRIES
3 Posts No Rating |
WHEN I MAKE INTERIOR ELEVATIONS IN REVIT ARCHITECTURE 9 AND PLACE THEM ON THE SHEET. SOME BOUNDRY LINES, MAINLY THE RIGHT BOUNDRY LINE DOESN'T SHOW UP. ANY IDEAS? hOSS mASLOUSKI
You may want to search the archives to see more on this subject. Possible solutions are: 1 You can adjust your crop boundry slightly to assure that you include the wall edge. I think this is the best solution because it will give you the lineweight of your cut wall / ceiling / floor. 2. Another soultion that some use is to pull the crop boundry out beyond where you want then create a masking region with appropriate linework. I personally think this is anti REVIT. 3. Turn off crop region boundries in all view except interior elevations then set the switch to print the crop region boundry.
Interior Elevation Crop boundries |
Thu, Aug 13, 2009 at 12:13:24 PM
Problem with Interior elevations |
Fri, Feb 13, 2015 at 1:51:29 PM
Edit Topo Boundries |
Wed, Jun 17, 2009 at 3:35:27 PM
interior elevations |
Wed, Apr 11, 2007 at 9:43:04 AM
Interior Elevations Referencing Detail Numbers |
Sat, Oct 13, 2007 at 11:04:39 AM
