Forums >> Community >> Newbies >> revit 2009 - lights
Sat, May 31, 2008 at 6:50:45 PM | revit 2009 - lights
ginacang
4.5 Stars: 2 Votes
I am working in Revit Architecture 2009 and have placed some lights in a space.  Whenever I render the space with artificial lighting the photo is completely dark, even though the lights are turned on in the space... any thoughts?
Mon, Jun 2, 2008 at 10:55:13 AM | revit 2009 - lights
rkitect
rkitect Avatar
4 Stars: 29 Votes
Unfortunately, your eyes render a 60W bulb much brighter than the camera that is built into Mental Ray  Actually, Mental Ray renders an image the way a real camera would see it.  If you have ever taken interior photos you'll notice that your camera always tries to use the flash.  This is because it is too dim in a room for the camera to pick up enough light for an exposure.  This is what is happening to your rendered scene.  Try setting the exposure settings to "brighter" as opposed to the darker setting it comes set at by default.  Play around with it and see if this works.
Also, if you are using a model that was done in 2008 and you just opened it in 2009, replace the llights with the newer lights that are provided with 2009.  When you render, it should report how many artificial lights are being rendered in the scene.  If it says 0, you need to check your lights.  One other posibillity is that you are using the Sun and Shadows only setting.  You need to be sure you are telling it to render Artificial Lights.
HTH!
Revit 2009 Lights
Mon, Jul 28, 2008 at 4:43:50 PM
Lights not working when Rendering Sun and Articficial? Revit 2009
Wed, Mar 17, 2010 at 4:38:51 AM
Revit 2009 - interior rendering with exterior sun and artificial lights
Fri, Oct 10, 2008 at 10:25:18 AM
Interior Lights are not working in Rendering
Wed, May 5, 2010 at 12:33:18 AM
Revit always renders all of the lights
Fri, Aug 8, 2014 at 9:24:36 AM
Page generation time: 1.3568
