5 Users Online (3 Members):
Forums >> Revit Building >> Technical Support >> Confusion on Rooms
I have one column coming in between one of the room. Now when i do the column encasement using wall the room area gets changed. How can i get my actual area with column encasement? Thnx in advance
Now on the implementation stage.... |
Hi, pick in the column go to properties and uncheck "Room Bounding"
The column is coming from the one of the revit link so that option is not possible.
Try unchecking the room bounding on the walls.
In the left side "Room and Area" Settings-At wall finish, then pick in Area Plan then Area boundary and select the perimeter...
I figured it out. After selection the column encasement wall i uncheck the room bounding as suggeted by typhoon and everything is OK. But i think the elements from the link should be more inteliigent. Anyway thnx everybody
rooms?? |
Tue, Oct 29, 2013 at 11:10:18 AM
tags, symbols and annotation confusion |
Thu, Jan 17, 2008 at 11:13:31 AM
Deleting Rooms from Schedules |
Tue, May 8, 2012 at 8:30:32 PM
Rooms within Rooms? I think... |
Tue, Nov 9, 2010 at 11:45:56 AM
Programming spaces/rooms in Revit |
Fri, Jun 21, 2013 at 9:20:34 AM
