Forums >> Revit Building >> Technical Support >> Displaying a wall above the cut line
Mon, May 12, 2008 at 1:19:45 PM | Displaying a wall above the cut line
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I am just wondering alternative ways to display a curtain wall above my cut plane rather than using the Plan Region command. When I use the plan region command it displays the wall hidden line when i would rather it be wireframe to see the elements below.
Wed, May 21, 2008 at 12:44:45 PM | Displaying a wall above the cut line
LIZARD2806
3.5 Stars: 7 Votes
Assuming I understand what you are trying to do, I would do it this way:
Create a new level that cuts through the curtainwall.  And then make a new plan view of that level.  Uverlay that plan onto the floor plan, then use your linework tool to select the lines representing the two sides of the curtain wall and then turn off the overlay.  The lines will remain and the underlay will be gone.  Note that this is still the wall, so if you move the lines, you are moving the wall.  Also, if you hover over the lines with your mouse, the wall will highlight as if the whole thing were drawn on that view.
HTH
**Using Revit Architecture 2009, 2011, and 2012**
wall cut lines not displaying
Fri, Sep 19, 2008 at 3:31:05 AM
Wall Hosted Cut Wall Line Weights
Tue, Oct 20, 2009 at 8:13:34 PM
Cut wall sweep in line with top of angled wall?
Sat, Oct 15, 2016 at 11:38:08 AM
Cut Profile Line Weights (Revit Glitch?)
Tue, Aug 22, 2017 at 4:23:29 PM
Section cut lines
Tue, Feb 2, 2010 at 9:44:41 AM
Page generation time: 3.6558
