Forums >> Revit Building >> Technical Support >> blends using 2008architecture
Sun, May 11, 2008 at 2:32:10 AM | blends using 2008architecture
fifthtexas
hi
new to revit and learning off various books, trying to create a roof using the bend comand
how can i create a semi circular roof, have used rectangles but trying to use an arc to create a roof as an example
or a solid structure with rectangular base that curves around. any help please
regards
fifthtexas
england
Sun, May 11, 2008 at 4:32:45 AM | blends using 2008architecture
4 Stars: 205 Votes
If you could put some Images to know what do you want to do, it's more simple to us figure out and help.
You have the "ROOF" menu with options to do "any" Roof you want, rectangular, circular, semi-circular..., but, some times this options not enough to do what we want, so, that's when we must to use another tools of revit (Mass elements, create in place...) to make what we need.
Massing Blend
Tue, Mar 20, 2007 at 11:58:48 AM
curved ,sloping shade
Thu, Feb 9, 2006 at 5:42:58 PM
CONCEPTUAL MASS IS NOT THE SAME AS FAMILY?
Wed, Nov 30, 2011 at 8:59:40 AM
Sweep Blends / Void extrusion
Wed, Mar 11, 2009 at 2:42:08 PM
Sweep Blends
Thu, Mar 6, 2008 at 8:25:22 AM
Page generation time: 0.0146
