3 Users Online (1 Members):
Forums >> Revit Building >> Technical Support >> imported sketch up model and view range only sees roof>
12 Posts No Rating |
I imported a sketch up model and the view range is set to level 1 0'-0" elevation with top at 7' and cut at 4' yet i only see the roof? in the ceiling plan it shows the the walls and the furniture? I need to see the walls below the roof to create the revit model? whats going on? I made adjustements in view range and nothing seems to work. when i go to elevations everything looks right. also when i cut sections it only shows me the corresponding elevation and not an actual section> help
Import it into mass familiy first, imported skp or dwg files do not get cut by sections or plan cuts. You can see that information in the RCP because you sketchup model has no floor.
Regards,
Chris.
not sure how to import into mass family?
excellent that totally worked via mass family it recognizes all the info
View range and floors |
Fri, Aug 19, 2011 at 4:55:36 PM
Linked Model View Range Issue |
Mon, Mar 17, 2014 at 3:59:53 PM
Revit Roof View Range - Revit 2013 |
Wed, May 8, 2013 at 8:22:41 AM
Help - Sketch Up Models are hidden!? |
Tue, Dec 7, 2010 at 10:35:46 AM
view range of a link file |
Wed, Jul 30, 2008 at 3:51:37 AM
