Forums >> Revit Building >> Technical Support >> brick cap at top of wall
5 Posts No Rating |
i want to put a brick cap at the top of a wall. i want it to wrap around the top of the wall, all four sides. does anyone know how to do this? thanks in advance,
R.Shank
WHen you create your wall, you can add sweeps/reveals etc. to the wall, that way it becomes part of the wall family. If you select your wall you you go to edit, edit structure. When the window pops up go to preview, you will get a preview in plan, switch from plan to section. When you do, you get more buttons to work with. Click on the sweep, and add you cap profile.
Hope that helps
5 Posts No Rating |
THANKS ARNOSANDOVAL, IT HELPS ALOT BUT I CAN GET THE SWEEP IN THE SIDES ON THE WALL. ITS JUST A 2'6" LONG PEIR AND I WANT TO PUT A CAP ON THE TOP
Rather than embed the sweep in the wall type, I'd suggest just using a hosted sweep, wall sweep with the appropriate profile.
This will allow you to wrap around the ends of the wall also.
HTH.
5 Posts No Rating |
With a host sweep I still am unsure how to get the parapet cap to wrap around all 4 ends of a wall. I have a free standing wall my wall cap leaves 2 ends open?? Thanks in advance.
Edited on: Tue, Jul 22, 2008 at 10:30:17 AM
Hi SNAP, "I need a parapet cap to wrap around the end of a wall., to do this you must create a family "Generic Model Face Based", If you want to create a sweep or reveal, you must create a family with the "Profile" or "Profile-Hosted"... i prefer the last because in there we can choose if we want sweep, reveal, fascia, gutter and so one... If you don't get it tell me and i create a video for you...
Edited on: Tue, Jul 22, 2008 at 10:32:32 AM
5 Posts No Rating |
Typhoon, thanks alot for your help...if you could walk me through that process that would be great. Im still fairly new to this software.
Hi SNAP, can you wait? it's take a several minutes...
5 Posts No Rating |
sure, there's no rush...
SNAP this is the 1º video: http://screencast.com/t/GZnakMtV i'm create the second ok? see this....
5 Posts No Rating |
This is the second video, i think you go understand, sorry for my bad english: http://screencast.com/t/UlBBX7gVcPi
5 Posts No Rating |
typhoon, thanks alot for your help!
You Welcome SNAP...
can you send me the videos on how to do this. the links in the thread are no longer active.
im trying to find the easiest way to model this CMU wall with the brick trim all around. see pic
thanks
Sloped top of stone wall with wall cap on top |
Tue, Mar 29, 2005 at 5:25:07 PM
Precast Cap on wall profile sketch |
Thu, Mar 23, 2006 at 2:31:12 PM
Wall Sweep for 2 x 6 Sill and 4" Cap Block |
Thu, Feb 11, 2016 at 9:15:08 AM
Brick wrap around the top and sides of CMU wall |
Tue, May 10, 2016 at 10:04:28 AM
adjusting railing top cap extension |
Tue, Mar 3, 2009 at 3:22:46 AM
Members: | 1991383 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
