Forums >> Revit Building >> Technical Support >> Mend walls
Thu, May 1, 2008 at 3:00:13 PM | Mend walls
FTW73
In Revit 2008, is it possible to "mend" two colinear walls of the same wall type? Essentially if you delete the middle of an exterior wall to get rid of some bays, can you "mend" the ends of the walls on both sides of the deleted area to join it back together into one wall (so I don't have to re-input all the windows in the wall).
Thanks.
Thu, May 1, 2008 at 3:19:15 PM | Mend walls
mhans
3 Stars: 10 Votes
Hi,
 If you are talking  about to same wall type that lie along the same line, you can select the 2 walls and you'll see a dot (unfilled) at the common endpoint. Select the dot and drag it to either side along the same same wall. Notice that you now have a single wall.
Mhans
Motto: "No Post left behind"
Thu, May 1, 2008 at 11:58:05 PM | Mend walls
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is provided they have the same base constrain/top constraint and height.
Regards,
Chris.
Fri, May 2, 2008 at 6:46:09 AM | Mend walls
FTW73
That worked nicely for most of the walls.
For some reason others wouldn't do it. But it was simple enough to delete and redraw.
Thanks!
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 0.5649
