468 Users Online (10 Members): Show Users Online - Most ever was 658 - Thu, Aug 6, 2026 at 4:08:19 PM
Forums >> Revit Building >> Technical Support >> First Floor Level Marker Disappeared
Mon, Apr 28, 2008 at 11:10:29 AM | First Floor Level Marker Disappeared
kingkong
The Level 1 marker has disappeared from all elevations, sections, etc.  The first floor plans are still in tact.  I don't know when or how this happened.  The "Levels" graphic override is turned on.  I've tried to remake a new one but no luck.  It's not turned off in the "Reveal Hidden Elements".  The other levels are visible in all views.  Just level 1 is missing.  Please help!
Revit Architecture 2008.
Tue, Apr 29, 2008 at 8:17:52 AM | First Floor Level Marker Disappeared
First, make sure you have all worksets on.
Next, go to an elevation and turn on your crop regions and pull out your crop window both left and right to see if you pulled your level line beyond your crop regions.
Tue, Apr 29, 2008 at 8:36:14 AM | First Floor Level Marker Disappeared
kingkong
Ok.  Thanks but no success.  I turned all worksets on.  I turned the crop feature off so the elevation wasn't cropped (I didn't just turn the crop windo off), and "zoomed all to fit".  I still don't see a marker.  I tried the same on a section view and still no marker.  Did you have another suggestion?
Tue, Apr 29, 2008 at 9:03:30 AM | First Floor Level Marker Disappeared
If you click view then floor plan, is the missing level available to you in the drop down?
Tue, Apr 29, 2008 at 10:06:35 AM | First Floor Level Marker Disappeared
kingkong
Yes, the missing level is available as a new floor plan.
Tue, Apr 29, 2008 at 10:42:00 AM | First Floor Level Marker Disappeared
Have you used scope boxes?  They can control the viewing of datums.
Tue, Apr 29, 2008 at 11:09:54 AM | First Floor Level Marker Disappeared
kingkong
You got me on the right track.  I unchecked the Far Clip Active box, zoomed out and voila! There was the First Floor Level - way off in left field, with no level head on it, just a line.
Thanks!!
Tue, Apr 29, 2008 at 4:50:15 PM | First Floor Level Marker Disappeared
lunchtrayrider
3.5 Stars: 7 Votes
So you had the level plan-dimensionally adjusted outside of your view range?
Wed, Apr 30, 2008 at 7:36:35 AM | First Floor Level Marker Disappeared
kingkong
What do you mean by dimensionally adjusted?  But I did find the level marker far away from my building.
Tue, May 19, 2015 at 9:24:06 AM | First Floor Level Marker Disappeared
tussyswat
I have the same problem but in the list of find reffering views my first floor doesnt appears
Tue, May 19, 2015 at 10:56:23 AM | First Floor Level Marker Disappeared
tussy, please start a new thread with a complete question because tagging on here just doesn't make sense.
Odd Level/family placement issue
Thu, Jul 12, 2012 at 10:09:08 AM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Changing Level Heights and having corresponding objects move
Wed, Nov 29, 2006 at 5:03:12 PM
Section Mark Not appearing (i've checked the Hide scale...)
Wed, Jan 31, 2007 at 3:32:33 AM
Adding a reference elevation to an existing elevation marker?
Wed, Sep 17, 2014 at 7:57:46 AM
Page generation time: 0.3388
