Forums >> Community >> Newbies >> New to Drafting
Fri, Apr 18, 2008 at 6:41:47 PM | New to Drafting
myshtern
Hello, I'm new to drafting and I'd like to start learning asap. I'm having a hard time choosing what to learn though. Should I go with autocad or straight to Revit?
Thanks
Fri, Apr 18, 2008 at 8:00:07 PM | New to Drafting
coreed
coreed Avatar
4 Stars: 16 Votes
if you have gotten this far in life without having to use Autocad, then go straight to Revit.
Edited on: Fri, Apr 18, 2008 at 8:00:30 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Apr 19, 2008 at 12:43:26 AM | New to Drafting
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
To answer this question one should look at the area they want to work. If you work in an area that is predominately AutoCAD then I would learn that first or if it dominated by Revit then learn that one first. The area I work in is becoming more saturated w/ the usage of Revit, but there are still many firms out there using AutoCAD. Aside from those firms that are one or the other, they are also many firms that are using both. The firm that I work in is using both AutoCAD Arch. and Revit Arch. so I have to be able to support both of them and some of our drafters had to learn both.
I think in my opinion I would learn Revit first since I believe that it is much easier to learn than AutoCAD, (my opinion, I know it might not have been easy for those of us who were using AutoCAD for 20 years.)I would not however, disregard AutoCAD. Reason being, many of the clients, consultant that you might work with will not know or have a desire or need for Revit and it is very good for you to know the software that they are working with and how to handle the file types that they will be using.  Not to mention knowing both makes you much more marketable.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Would like to copy a drafting view from one project to another. [ 1 2 ]
Mon, Jan 4, 2016 at 6:07:17 PM
17
batt insulation fill pattern (drafting)
Thu, Nov 1, 2012 at 1:03:19 PM
Drafting view
Thu, Aug 6, 2015 at 1:41:00 PM
Rebars - Stirrups Tie in Drafting View
Wed, Aug 1, 2012 at 9:47:36 AM
Page generation time: 0.1009
