554 Users Online (60 Members):
- Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM |
Forums >> Revit Structure >> Technical Support >> How to find the missing void object in family
Hi all I have put a void sweep in a family (together with some solid objects) and multiple cut some elements outside the family. Now i wanna make some changes to family but since i cannot recall void object inside the family, i cannot apply "uncut" on the objects, so it keeps giving error messages. I know that when you cut sth the void always appear when you move cursor over the cutting surface, but not this time. I tried to do it in and out the editing mode of the in-place family, but didnt work!?!. When i try to erase the cut elements (outside the family) the whole family disappears. thx ps: i use ra 2008
Edited on: Thu, Apr 17, 2008 at 10:34:03 AM
9 Posts No Rating |
hi, how about isolating the family, then select all by crossing window. and then use filter selection - does the void sweep finally appear in the selection checkboxes?
Hmm good idea, thx. Should give a try (i deleted and redone everything at that problematic point)
3 Posts No Rating |
Hi, other option: if it gives you warnings / error messages with the void sweep, you can look up it's elememt ID (in tools - review warnings) and in Family editing mode you go to tools - element IDs - select by ID, enter the ID of the void and edit or delete or whatever you like to do with it now, as it is selected!! I do loads with in place void families and find this works best! k
Create.NewFamilyInstance isn't displaying a new family on sheet |
Mon, May 9, 2011 at 1:06:22 PM
RevDev Studios - RevEx and RevXL - Spreadsheet plugins for Revit |
Tue, Feb 28, 2017 at 7:32:28 AM
Modelling terrain Revit imported from AutoCad |
Thu, Oct 20, 2011 at 9:29:49 AM
Revit 2016 Annotative Demo Tag Formula |
Mon, Apr 25, 2016 at 2:30:59 PM
New Website Launch of Free Revit Add-on Smart Browser |
Sun, May 20, 2012 at 2:50:40 PM
Members: | 2189245 | Objects: | 23399 | Forum Posts: | 152445 | Job Listings: | 0 |
