Forums >> Revit Building >> Technical Support >> twin height brick pattern
Mon, Apr 7, 2008 at 8:44:30 PM | twin height brick pattern
puzzle
4 Stars: 10 Votes
I'm looking for a twin height brick model pattern. 240mm long x 160mm high.
Macca
Sunshine Coast
QLD Australia
Tue, Apr 8, 2008 at 6:34:15 AM | twin height brick pattern
Just edit another pattern, these are just a text file.  You should be able to dowload one of the model brick patterns here and be able to identify the different x & y dimensions in that.  Then just change those, save the file to a new name and load it.
It's very easy to do so taling the time to learn it now will pay good dividends later.
Pattern brick wall
Thu, Nov 17, 2011 at 7:15:35 PM
Help with brick hatch
Mon, Oct 27, 2008 at 5:39:36 PM
11
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
Page generation time: 0.3700
