9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Is there a standard Revit Filing Sysytem?
4 Posts No Rating |
Is there a standard filing system used to organize revit projects? Our company is trying to implement a filing system standard that will help organizes revit files as well as projects. The company is moving away from an AutoCAD based filing system and within that system we have subfolder that includes design phases. Any suggestion or comments welcome. Thank you -Nathoon
We use the MasterFormat CSI standard for our Revit families. In our project folders, we have a separate folder for Revit and include in that folder all project specific families and files. As far as design phases go, we usually use design options until the design has been set, then transfer it all back into the main file (sometimes a pain). Not the most efficient way of working, but its been getting the job done for us. We also print as PDF's the project as it comes out of each design phase (from schematic to design development to construction documents) just to have a record of where the design has been. So, to answer direct, no, there is no standard filing system. That's one more area of working that you'll have to set up for your own office.
Ruth Rau Main Street Architecture, P.C. |
Revit Filing System |
Sat, Aug 16, 2008 at 1:48:52 AM
How to make sheet parameters RELATED |
Thu, Nov 26, 2015 at 5:48:30 AM
Linking Standard Sheets from Revit |
Wed, Mar 17, 2010 at 4:16:17 PM
Plumbing insulation |
Thu, Feb 20, 2014 at 7:41:36 AM
Standard Details In Revit [ 1 2 ] |
Thu, Dec 19, 2013 at 11:25:53 AM
16
