96 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> Room
Good news .... thanks for the update. Do you think it was only this?
Well the warnings had a lot to do with it. But, after I cleared those out and it was still causing issues, I tried it on another machine in the office and it worked fine. Then, I somehow remembered to check the build on the program. Then it worked. So it was a combination adn this was merely the last step in fixing the issue. The gbXML warnings are something to avoid. If you need to export gbXML, just save a copy file for exporting. Rather than getting all your Revit warnings in your working project file.
Denver, CO
Revit Architecture |
room bounding not recognizing room separation line [ 1 2 ] |
Thu, Aug 18, 2016 at 10:02:14 AM
16
ROOM TAG TAGS ONLY HALF OF THE ROOM |
Wed, May 6, 2015 at 8:58:21 AM
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
box around room number on room tags |
Sun, Dec 13, 2020 at 9:59:00 AM
Room Problem |
Mon, Jan 23, 2012 at 9:09:06 PM
Members: | 2001654 | Objects: | 22887 | Forum Posts: | 152181 | Job Listings: | 3 |
