Forums >> Revit Structure >> Technical Support >> Changing level elevation for entire model on all floors
Fri, Feb 22, 2008 at 4:54:24 PM | Changing level elevation for entire model on all floors
awilly
The model was started with the basement elevation at 0'-0". The architect now wants the basement elevation to read 113'-0". Can I move the entire model up and have the elevations automatically change or do I have to move each floors elevation individually?
Mon, Feb 25, 2008 at 8:29:20 AM | Changing level elevation for entire model on all floors
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You will need to first go to Tools-->Project Location/Orientation-->Relocate This Project then open an Elevation and Click a point and drag up or down the desired amount. This will relocate the entire project vertically. To make your level markers read this number; right click the symbol and go to Properties-->Edit/New. Change the Elevation Base parameter to "Shared". Apply and Close.
Wed, Dec 10, 2008 at 7:21:40 PM | Changing level elevation for entire model on all floors
Fluffyfatcat
3.5 Stars: 3 Votes
hi guys, I just relocated my project following Jameshgrimes recommendations, all works fine, just have to remember to have all spot elevations levels set on shared as well.
My problem is a toposurface, i can't give it "shared co-ord.? can I, i can only physicaly move it down, but then all topo levels are not to a Land Survey or should I set up a toposurface as a separate file and link my model? cheers
How to move a single level datum without moving anything in model
Tue, Sep 29, 2015 at 1:53:58 PM
Move half of entire project down vertically
Tue, Aug 4, 2015 at 10:35:42 AM
Changing model constraints from one level to another
Wed, Aug 12, 2015 at 3:29:36 PM
Trying to move entire model to a different level!!
Thu, Jan 28, 2010 at 2:18:31 PM
Elevation Markers: visible on all floors
Mon, Nov 7, 2011 at 12:24:27 PM
Page generation time: 0.8851
