Forums >> Revit Building >> Technical Support >> Coordinating project placement with Autocad
Wed, Feb 13, 2008 at 3:57:05 PM | Coordinating project placement with Autocad
mcsarch
I am designing an apartment building in Revit. This project must be correctly located in a large masterplan. When importing the Autocad property lines into Revit, the program refuses to import "origin to origin" and insists on placing it "center to center". When exporting the building from Revit, no matter the placement within the file, the building ends up in the same place (the wrong place) in the Autocad file. Can anyone help me figure out how to get the file to place to the correct coordinates in Autocad?
Wed, Feb 13, 2008 at 4:44:01 PM | Coordinating project placement with Autocad
coreed
coreed Avatar
4 Stars: 16 Votes
have a look matte. this should do it
http://autodesk-revit.blogspot.com/2007/09/shared-coordinates-true-north-project.html
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Feb 14, 2008 at 9:49:00 AM | Coordinating project placement with Autocad
mcsarch
Thanks for the post!! I am definitely a lot closer to my answer. The problem is that once everything is set in Revit and I export the file back into Autocad, the building is still way off mark. The coordinates match from the original Autocad file to the Revit file, but once the Revit file is exported back to Autocad then I loose the alignment. Is there anything I can do about this? I am outside of the 1 mile radius, so I figure, maybe, this is most of my problem.
Thu, Feb 14, 2008 at 10:06:18 AM | Coordinating project placement with Autocad
mcsarch
OK, so after some trial and error with the exporting options, I have gotten it to work! Change the "coordinate system basis" in the options to "shared" and it lands in the correct place in Autocad. Thanks for the help!
Thu, Feb 14, 2008 at 10:16:07 AM | mcsarch
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting mcsarch from 2008-02-14 10:06:18
"OK, so after some trial and error with the exporting options, I have gotten it to work! Change the "coordinate system basis" in the options to "shared" and it lands in the correct place in Autocad. Thanks for the help!"
i thought that information was contained in the linked post. thanks for posting how you solved the problem. every little bit helps.
Edited on: Thu, Feb 14, 2008 at 10:17:21 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Model/Viewport placement Modelspace/Paperspace when exported to AutoCad
Thu, Nov 12, 2009 at 10:01:09 AM
Splitting part of a Revit Project to AutoCad
Sat, Nov 22, 2008 at 7:06:27 PM
Placement point in a family
Thu, Nov 2, 2006 at 5:25:49 AM
Coordinating faced based models with Revit MEP
Tue, Feb 2, 2010 at 4:07:04 PM
Handrail Deletes when adjusting baluster placement?
Tue, Aug 27, 2013 at 8:03:27 PM
Page generation time: 1.1534
