Forums >> Revit Building >> Technical Support >> Subregion size
Fri, Mar 4, 2005 at 5:56:56 PM | Subregion size
kfpopeye
Does anyone kow is there a limit to the size or complexity of a subregion? I was creating some complex road regions and when I got to a certain point I couldn't finish the sketch. Whenever I pressed "Finish Sketch" nothing would happen (no error messages nothing). But if I created the roads as two seperate subregions it worked fine.
Sat, Mar 5, 2005 at 12:46:38 AM | RE: Subregion size
TomDorner
4.5 Stars: 25 Votes
I don't think there is any limit to the subregion size. However they seem to not behave correctly all the time. I have run across the same error and I just worked around it like you. I've had such bad experiences with subregions I have started going back to splitting the topo surface as it is more reliable. Tom
Subregion changes topo's elevation?
Mon, Nov 24, 2014 at 4:12:40 PM
Toposurface&subregion problems
Thu, Apr 16, 2009 at 1:47:06 AM
revit topography subregion stretched material
Mon, Jan 4, 2016 at 2:57:07 PM
Dang Topo Subregion!
Wed, Jul 11, 2012 at 2:02:54 AM
Filled subregion visible on area plan
Wed, Jan 13, 2010 at 5:58:31 AM
Page generation time: 0.5995
