56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how to make door frames cut wall sweep?
Fri, Jun 6, 2008 at 9:13:17 AM | how to make door frames cut wall sweep?
#16
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Yea, I didn't think about the windows. My method will only work if the entire sweep is cut vertically by an opening. sorry
Fri, Jun 6, 2008 at 12:55:02 PM | how to make door frames cut wall sweep?
#17
LIZARD2806
3.5 Stars: 7 Votes
So, when you add a wall sweep, at the location it hits the dorr, you don;t get any of the blue grips?  I drew an out of the box wall, with an out of the box door, and an out of the box sweep and it works for me, see image.  I pulled the sweep back further than the frame for illustrative purposes.  But is this kind of what you are trying to do?
**Using Revit Architecture 2009, 2011, and 2012**
Fri, Jun 6, 2008 at 1:52:58 PM | how to make door frames cut wall sweep?
#18
NancyHKA
this is exactly what I'm trying to do, but, for some weird reason, when you check "cut by wall inserts" (which I need to do to cut out the windows), the blue dots at the door disappear.
Fri, Jun 6, 2008 at 2:10:07 PM | how to make door frames cut wall sweep?
#19
LIZARD2806
3.5 Stars: 7 Votes
OK.  Now I see.  To be honest, the way I would do this is not with a wall sweep, but I would make another wall type for the pad, draw it along side the exterior wall and then join them.  By doing this, when one wall moves, the other will as well and once joined the windows and doors should cut both of the walls.  I have done this before when I had to put new tile on an existing wall.  It worked pretty well.
If you want to stick with the wall sweep and there are not too many windows, you can create a void elelment and cut it out of the sweep, but if there are a bunch of windows it could get messy.  (see image for example).  Good luck!
HTH.
Fri, Jun 6, 2008 at 2:27:11 PM | how to make door frames cut wall sweep?
#20
NancyHKA
thanks!  I will give that a try.
Mon, Jun 9, 2008 at 8:11:27 AM | how to make door frames cut wall sweep?
#21
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I agree with LIZARD2806. I would make a new wall type. I didn't think of that before but that is a good idea.
Wall Sweep Overlaps window frames and cuts (some not all)
Mon, Jun 22, 2015 at 8:09:40 AM
Profiles, sweeps, and door frames...
Tue, Mar 3, 2009 at 7:03:51 AM
Wrapping Door Frames and Internal Door Frames [ 1 2 ]
Mon, Aug 11, 2008 at 11:02:26 AM
15
Door Frames
Fri, May 16, 2008 at 8:46:11 AM
gap in wall sweep without wall opening?
Thu, Apr 22, 2010 at 3:14:20 PM
Page generation time: 1.1492
