Forums >> Revit Building >> Technical Support >> Rotating Roofs
Mon, Feb 22, 2016 at 11:18:11 PM | Rotating Roofs
David Ewing
Using Revit Architecture 2015
I have modeled a small building with intersecting gable roofs. It conforms to the town main height limit, but it intrudes into a secondary height limit/setback which is defined as follows: at the required rear setback line, I need to project the site slope along that line 15' into the air. The rear elevation of the building, which is right on the setback line, can be no higher than this. In my case this line is 3 connected sloping straight lines that are around 2 to 3 in 12 slope. From this setback toward the interior of the lot, the allowable building envelope rises perpendicular to the rear setback envelope that I described at 1:1, or a 45 deg. angle.
In order to re-shape my building to fit under this, I thought I would create a Revit roof as a shell to represent the height limit in 3D. I started by drawing the 3 segment sloping line and doing a roof by extrusion, which resulted in a pitched roof following these slopes but with horizontal ridges and valleys instead of sloped ones. I thought I would then go to a side view and rotate it 45 deg., or try to specify a 12:12 roof slope along the edge at the back wall. Revit gives me a "you can't do that" message with no further explanation. Same response when I try Roof by Footprint, Face, or if I try to use a Mass. Any ideas on how to model this? Thanks!
Tue, Feb 23, 2016 at 6:58:13 AM | Rotating Roofs
mansell5
3.5 Stars: 4 Votes
a picture tells a 1000 words, how about posting a 2d detail explaining it all?
Tue, Feb 23, 2016 at 7:08:07 AM | Rotating Roofs
Way too complicated too read and understand.  You should have done a sketch showing the requirements.
Tue, Feb 23, 2016 at 12:50:17 PM | Rotating Roofs
David Ewing
Here are two elevations annotated to illustrate my question above:
Tue, Feb 23, 2016 at 1:54:01 PM | Rotating Roofs
I don't understand.   From your second image, the structure appears to be too tall already and this view shows the limit.  Why complicate this when sctions will work.
Or just do a single roof plane for each side.
Edited on: Tue, Feb 23, 2016 at 3:29:26 PM
Tue, Feb 23, 2016 at 4:27:57 PM | Rotating Roofs
David Ewing
I can't cut study sections until I create the height envelope in 3D because it slopes in two directions. I am attaching a 3D screen shot of my progress object. I hope it helps you understand.
Edited on: Tue, Feb 23, 2016 at 4:33:04 PM
Tue, Feb 23, 2016 at 4:28:03 PM | Rotating Roofs
David Ewing
I can't cut study sections until I create the height envelope in 3D because it slopes in two directions. I am attaching a 3D screen shot of my progress object. I hope it helps you understand.  PLEASE DELETE THIS DOUBLE POST (SAME AS #6 ABOVE), I COULDN'T SEE HOW.
Edited on: Tue, Feb 23, 2016 at 4:32:20 PM
Edited on: Tue, Feb 23, 2016 at 4:33:46 PM
Edited on: Tue, Feb 23, 2016 at 7:55:12 PM
Tue, Feb 23, 2016 at 5:01:52 PM | Rotating Roofs
mansell5
3.5 Stars: 4 Votes
why not treat the envelope you want to create as a series of very thin roofs on 45 deg pitch- 1 for each slope plane as shown in your sketch.
where the roofs intersect , trim them and then join them.
then assign them as a semi transparent material so you can more easily see where your proposed model roof will intersect these.
in other words rather than trying to make this envelope thing in 1 go, make it 3 separate pieces and join/group.
hope this helps.
Tue, Feb 23, 2016 at 5:27:44 PM | Rotating Roofs
David Ewing
Thanks for the reply. I understand what you are saying as far as the final object, but don't know how to this step: In creating the first of 3 rectuangular planes, how do I get it to slope in two directions?
Thanks!
Tue, Feb 23, 2016 at 6:49:54 PM | Rotating Roofs
Bartholomew
5 Stars: 2 Votes
David, I feel your frustration. I am frustrated too trying to figure out what you can’t do exactly. May I ask: Can you visualize and sketch on a piece of paper what you want? If so: then maybe you could post that sketch so we can see your vision.  An isometric sketch would help us to help you.
Tue, Feb 23, 2016 at 7:54:04 PM | Rotating Roofs
David Ewing
Bartholemew,
I did attach an annotated isometric sketch in post #6 above, please take a look.
Tue, Feb 23, 2016 at 8:11:26 PM | Rotating Roofs
Bartholomew
5 Stars: 2 Votes
Yes, I saw that David. Thanks. What I think would be more helpful is to see what you visualize it should look like. You want to get Revit to "reshape" the image in post#6 to look like what?
Wed, Feb 24, 2016 at 7:43:46 AM | Rotating Roofs
#13
blue442
blue442 Avatar
I may be completely misunderstanding everythign here... but... why not use a model in place component.  It seems like you could just sketch each shape and extrude them.  Join them, crate voids to hack away parts. You already have your work planes based on the roof, and the lines on the elevation right?
Wed, Feb 24, 2016 at 10:53:59 AM | Rotating Roofs
#14
Bartholomew
5 Stars: 2 Votes
Might be easier to just go the City and ask for a variance. Ha! Sorry, couldn't help myself.
Edit: David, have you tried using a floor instead of a roof? By doing so, you can use Modify Sub Elements to sculpt the shape your looking for - if it is a shape your after. Still unclear on that however.
Edited on: Wed, Feb 24, 2016 at 11:37:03 AM
Wed, Feb 24, 2016 at 12:39:35 PM | Rotating Roofs
#15
Bartholomew
5 Stars: 2 Votes
It just occurred to me what you’re trying to do: a 3D tent or envelope like is shown in this attachment. I suspect your modifying for reuse an existing product. Am I right? Anyways – use the method I described above: Floor-Modify Sub Elements.
Components not rotating with project
Fri, Feb 16, 2007 at 10:19:33 AM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Page generation time: 0.0803
