Forums >> Revit Building >> Technical Support >> Insulation layer wrapping the wall
Wed, Sep 3, 2014 at 11:44:20 AM | Insulation layer wrapping the wall
glenlake
3.5 Stars: 3 Votes
Good afternoon all!
Does anyone have created two walls with rigid insulation which wraps them in a plan view smoothly?
(Structure/ Wrap toggle does not help). Adding a separate wall does not work as well: when I disallow join, it is not what I want. When I allow join, it joins the concrete wall and “sinks” in it. Is there a predefined way to do this in Revit 2014?
Please share your experience.
Thank you.
Wed, Sep 3, 2014 at 12:41:20 PM | Insulation layer wrapping the wall
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Create your perimeter insulation wall some distance away from the concrete wall, trim the corners (if needed) then use align tool to move the insulation wall in its place where you want it.
When you model a furring wall aligned/touching another wall, furring wall doesn’t want to trim corners nicely.
Wed, Sep 3, 2014 at 12:57:41 PM | Insulation layer wrapping the wall
blue442
blue442 Avatar
i could not find a way to make those wraps.  i would either do infill pieces or do the interior wall as a secondary wall everywhere.
Wed, Sep 3, 2014 at 1:35:15 PM | Insulation layer wrapping the wall
glenlake
3.5 Stars: 3 Votes
Thank you for the advice. Now I seee that there is no "official" way to do it. I tried what you describe, but the wall, when I align it to the right  place, merges with the concrete wall and disappears inside it.
Wed, Sep 3, 2014 at 2:01:07 PM | Insulation layer wrapping the wall
blue442
blue442 Avatar
after playing with this some, i think it is because you are changing wall thickness.
using that specific condition, i am also having problems.
when we do a simple corner turn, we do not have this issue.
perhaps the wall should be modeled differently.  Is it a column at a foundation wall?
Not sure what to tell you.
Wed, Sep 3, 2014 at 2:02:36 PM | Insulation layer wrapping the wall
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
I always model furring walls as a separate wall. Take a look at this video: http://www.screencast.com/t/t2dtWuSqU1ds
Is this what you're looking for?
Wed, Sep 3, 2014 at 2:30:01 PM | Insulation layer wrapping the wall
blue442
blue442 Avatar
i noted a difference in the way the two of you handle your wall.
in the original post, i took it that the thicker wall was a single wall.  in your screencast, the wall was a secondary wall aplied to make it thicker.
if you use a single wall (thicker) it will fail as we were discussing.
Wed, Sep 3, 2014 at 5:01:16 PM | Insulation layer wrapping the wall
glenlake
3.5 Stars: 3 Votes
You way is much better for these walls couldhave different phases, what is very important in many practices. I used both ways (in my sketch you see both approaches), and both failed. This video shows exactly what I want to have.
But I could not succeed in this operation from the beginning. What I am doing wrong?
Thank you for the video and for the advice. They inspired me.
133966_Separate_walls__step_1-_concrete_and_furring_before_joining.JPG133966_Separate_walls_step_2-_concrete_and_furring_after_joining.JPG
Wed, Sep 3, 2014 at 5:15:09 PM | Insulation layer wrapping the wall
glenlake
3.5 Stars: 3 Votes
Yes, I thought it might be related to the thickness of the conc. wall. I made it thicker and wider - partly it works, but the two side thin conc. walls cannot extend to the thick one and not join it. The best thing I reached is not joined connestion (I disallowed join of thin walls), but it does not work with the project dimensions.
Wed, Sep 3, 2014 at 5:31:52 PM | Insulation layer wrapping the wall
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Ok, this is a little bit different than your original picture. Revit doesn’t like this condition (very short walls) too much, but you can try using Wall Joins tool and maximize the length of those short walls – see pic.
Wed, Sep 3, 2014 at 5:32:28 PM | Insulation layer wrapping the wall
#11
glenlake
3.5 Stars: 3 Votes
I've got it!
First, disallowed join of all the concrete walls, then placed the furring walls at the desired place (they were joined and looked nice), then dragged the thin conc. walls to the tick walls (they were still not joined), worked a little on somethhing else (it also might be a factor in such a wierd process), then went back to these walls and joined them with the Join tool.
But on he video it is much more simple!
Thank you all for help!
Wed, Sep 3, 2014 at 5:38:15 PM | Insulation layer wrapping the wall
#12
glenlake
3.5 Stars: 3 Votes
Thank you for pointing me at the Wall Joints tool. It is always the last resort.
But I wish to be able to do it as nicely and simply as it is on the video.
Thu, Sep 4, 2014 at 7:47:22 AM | Insulation layer wrapping the wall
#13
blue442
blue442 Avatar
I think this comes down to the way the walls were created.  I noticed in the screencast that was previously created that it looked like two walls were put together to make the column bump out...
Check out the video i threw together for you.  it depicts how the walls are created can impact the interior wrap.
https://screencast.autodesk.com/Main/Details/359427f2-8efd-4ef2-8f69-126dd5d78a33
Edited on: Thu, Sep 4, 2014 at 7:49:04 AM
Thu, Sep 4, 2014 at 8:48:15 AM | Insulation layer wrapping the wall
#14
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Interesting, …I’ve never run into that before. My example shows structural column and continuous concrete wall running through the column. Nice find Blue.
Thu, Sep 4, 2014 at 10:53:30 AM | Insulation layer wrapping the wall
#15
glenlake
3.5 Stars: 3 Votes
Very interesting!
wrapping wall materials
Thu, Aug 14, 2008 at 4:40:22 PM
Wall Wrapping
Wed, May 11, 2016 at 1:55:23 PM
Cutting isolation wall layer with beam inside
Thu, Apr 20, 2017 at 4:12:08 PM
wall layer not wrapping for door family with jambs
Tue, Sep 1, 2015 at 10:34:33 AM
Controlling roof and wall joins in revit 2009
Thu, Apr 9, 2009 at 10:09:40 PM
Page generation time: 0.5947
