Forums >> Revit Systems >> Technical Support >> Custom Hatch Patterns on Revit
Thu, Aug 26, 2010 at 4:48:26 PM | Custom Hatch Patterns on Revit
vhugomg
Hi, I´m trying to make a Custom Hatch Pattern by entering codes on a notepad so revit may be able to read it, but I´m just do not know what am i missing following the procedure of info. I just cannot do it not matter what I do including the years and years of trying, Sad, jajjaja.
 Would you help me resolving this issue?, I already draw my pattern manually on the 4 fachades of my project, but I preffer to erase those detail lines and let a good custom pattern be part of the drawing.
 I know this example will help me and all the revit comunity to solve the custom hatch pattern.
 Thanks a lot and my best wishes...
Thu, Aug 26, 2010 at 10:58:59 PM | Custom Hatch Patterns on Revit
hugh
3.5 Stars: 4 Votes
Here's an INCH version
;%VERSION=3.0
;%UNITS=INCH
*VHUGOMG,Revitcity
;%TYPE=MODEL
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.
;        www.cadro.com.au/hatchkit/
0,0,0,0,3.5
0,0,2.5,0,3.5
90,0,0,0,2.4
If your measurements were in metres note Revit patterns are in MM:
;%VERSION=3.0
;%UNITS=MM
*VHUGOMG,Revitcity
;%TYPE=MODEL
;        www..hatchkit.com.au
0,0,0,0,3500
0,0,2500,0,3500
90,0,0,0,2400
Hugh Adamson
www.hatchkit.com.au
Sat, Aug 28, 2010 at 12:28:36 PM | Custom Hatch Patterns on Revit
vhugomg
Wooow, it worked. You´re a genius, thank you very much!
Sat, Aug 28, 2010 at 1:14:45 PM | Custom Hatch Patterns on Revit
vhugomg
Here's an image of the pattern applied to the building. Thanks!
Fri, Oct 15, 2010 at 12:43:24 PM | Custom Hatch Patterns on Revit
vhugomg
Sorry for asking again, but although I'm having progress on making hatch patterns on revit, I cannot make circles on patterns like this one I am uploading. It´s a concrete panels hatch with little circle marks . Would you mind telling me the parameters or coordinates for this pattern, I appreciate your help!.
Fri, Oct 15, 2010 at 12:50:21 PM | Custom Hatch Patterns on Revit
vhugomg
I forgot, the parameters of the lines in the pattern are:
90,0,0,0,1220
0,0,0,0,2440
I just dont know how to insert the coordinates for the circles...
Fri, Oct 15, 2010 at 4:10:10 PM | Custom Hatch Patterns on Revit
You can't make circles in hatch patterns.  You could approximate with small lines but...I would not even try.
Fri, Oct 15, 2010 at 5:03:13 PM | Custom Hatch Patterns on Revit
vhugomg
It is possible, have you ever seen the pattern of stones or roof tiles with half circle arc? It really is possible...
Sat, Oct 16, 2010 at 12:30:18 AM | Custom Hatch Patterns on Revit
hugh
3.5 Stars: 4 Votes
Hatch pattern definitions are made up entirely from straight lines, curves are always approximated by short segments.
For example the attached HatchKit pattern approximates a 10mm circular hole with 5 lines (a pentagon).  Using a small square would simplify calculations if you wanted to create the hatch pattern with a test editor as their short side segments would then line up in this pattern.
Hugh Adamson
www.hatchkit.com.au
Wed, Oct 20, 2010 at 10:17:08 PM | Custom Hatch Patterns on Revit
vhugomg
Thanks man, for attending my second question on this subject. I will really consider to buy a hatchkit tool asap ...and you are a genius!
Best Regards...
Wed, Nov 10, 2010 at 11:48:43 PM | Custom Hatch Patterns on Revit
#11
JohnHans
You should try myHatch, its free and it work so well.
 You need to add some parameter later on, but it is an easy task.
Revit Architecture 2011
Wed, Nov 24, 2010 at 1:13:34 PM | Custom Hatch Patterns on Revit
#12
vhugomg
Thank you, I appreciate your advise. I am downloading it right now.
Have a nice day!
Sat, Jun 27, 2020 at 1:19:53 AM | Custom Hatch Patterns on Revit
#13
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Here is DynaPAT which can create any pattern you want in Revit directily.
https://plevit1.blogspot.com/2020/06/dynapat-pattern-maker-for-revit-by.html
A sample pat file which is created by DynaPAT is attached.
EnjoyRevit is back. Smile
want more?
You can get more tips at Enjoy Revit
Sat, Jun 27, 2020 at 6:34:35 AM | Custom Hatch Patterns on Revit
#14
That is a large file!  What does the pattern look like?
Sat, Jun 27, 2020 at 6:41:16 AM | WWHub
#15
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
Quoting WWHub from 2020-06-27 06:34:35
This is it.
want more?
Thu, Dec 23, 2004 at 3:00:32 PM
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:02 PM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:25 AM
15
How to scale Hatch Patterns already loaded in file?
Tue, Apr 19, 2011 at 3:11:31 PM
Stone Hatch Patterns - Looking for a good source.
Sat, May 4, 2013 at 4:59:24 AM
Page generation time: 3.5936
