I make this object for break waves, cause we have more than 18.000 islands...Surya Consultant, Tual, Maluku Tenggara, Indonesia.. |
1508 Downloads
Generic 1.5m long 800mm high 300mm wide road traffic barrier |
No rating |
1060 Downloads
24' Above Ground Swimming Pool
5' 5" High
4' High water |
Product Version: Unknown
15793 Downloads
2019 Revit File - 30' Yurt Home with Basic Interior and Loft Space Layout with Sparse Furniture
This is not a Revit family or .rfa but rather an Revit file but as of time of posting nothing existed that was Yurt Like.
Please rate :) |
1726 Downloads
Fully parametric spans, height etc. Automatically change thickness of sructural raft, slab & walls. |
No rating |
2421 Downloads
8' Gazebo based on a design that I found online. Materials are parametric. Visibility parameter for pier foundation. |
26479 Downloads
FULL SIZING AND MATERIAL PARAMETERS. FACE-BASED SO CAN BE PLACED ON ANY SURFACE. REVIT 2025. |
No rating |
55 Downloads
Aluminum tube fence with 4" square fence posts and 1" pickets.
This is a generic model with an instance parameter set to easily change fence lengths (for some reason does not work well under 15' long) - just save out the single section as its own file for shorter lengths.
Had fun playing with the formulas to get sections added and fence posts evenly spaced with the pickets staying less than 4" clear between each other.
Please rate/comment.
Thanks! |
35638 Downloads
Angel Statue |
No rating |
Product Version: Revit Architecture 2019
4208 Downloads
Apollo Statue for Exterior Landscape |
No rating |
3991 Downloads
Exterior round roof archway supported by Posts on each side. Parametric family |
24836 Downloads
Barcelona Pavilion Statue CAD import with custom OOTB material |
No rating |
2184 Downloads
This here is a stage. It is approximately 750 square feet (which is about 70 square meters). You can change the text on the sign if you want to. (Greggo and the Romans is the name of a local band from where I live.) |
11455 Downloads
Nice Earth tones to go with the landscaping of a home. |
No rating |
2843 Downloads
This is a post based on Disney Boardwalk Hotel posts |
No rating |
Product Version: Revit Structure 2017
1312 Downloads
Full parametric element.
You can set the length of fence, the material, the height of fence...
When you set the full length then the fence make automatically the allocations.
Much more full parametric elements:
www.revittuning.com
Comming soon |
Product Version: Revit MEP 2010
50037 Downloads
You can set the length of fence, the material, the height of fence and the slope of land, etc...
Reloaded the previous version.
Much more full parametric elements and this element with analysis function:
www.revittuning.com
Comming soon
Ps.:
Thanks to someone for the rate... :-D |
14596 Downloads
Bruce Lee Statue for Exterior Landscape |
941 Downloads
Bull statue for exterior landscape |
2323 Downloads
(Made in Revit)..but this is a DWG ... AutoCAD 2010 :) |
4959 Downloads
Statue of Caesar |
No rating |
1366 Downloads
Posts and a roof but done as a learning exercise so parameters for everything from roof pitch to timber size and spacing. |
15601 Downloads
Fully parametric canopy system based on the Mitchell Metals canopy system. Allows you to drag it to the correct size and places the supports as required and recommended by the manufacturer. The width/height is controlled to correspond to the manufacturer's maximum recommended dimensions. The parameters are shared between the support and the canopy system, you will most likely need to create the shared parameters in your own project or use the attached file. |
No rating |
4909 Downloads
Parametric, adaptive chainlink fence |
No rating |
11080 Downloads
Fully parametric Chainlink fence. Works at any length. |
13108 Downloads
Updated parametric chainlink fence. Fixed an issue with post caps visibility parameter.
Added ability to slope fence using a 'delta elevation' parameter |
33298 Downloads
Attached is a clothes line which is to be fixed to a wall. This is at fixed dimensions of 2400 length and 1200 wide.
20923 Downloads
![Colorbond fence [parametric]](object_docs/9122_s.jpg) |
Here we go, a great parametric colorbond fence which adapts to the site slopes. Just follow the instructions to use it: First of all, it only works as linear arrays, never curves. 1) Insert the component making sure its host is the site surface. 2) Measure the total distance of the line you want the fence on and subtract 60mm, which is the post diameter. 3) Divide the total by the panel length, for example 2100mm. Example: if we have 22578mm to fence, subtract 60mm and divide by 2100mm. That gives me 10.72 4) Round this number to the next integer. In this case 10.72 becomes 11. 5) Divide the total (22518mm) by 11. 6) Open the Fence Properties and change its length to the result (2047.09). 7) Create an array of 11 parts with the panel. 8) That's it. Done! |
21502 Downloads
Here is a courtyard wall 1500 high with a brick hob. |
5016 Downloads
There are three layouts for this covered bench, just choose which one you want.
1. Table with bench both sides
2. Table with full bench and adad area on other side
2. Table with no bench |
5425 Downloads
