174 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Arched Opening in a Curved Wall
The step by step is eldados's post... follow it. My only add is that the reference plane is perpindicular to the center line of your opening and use a section or elevation that cuts parallel with that plane.
You got to start the process.......we can't do that for you.
His steps look so simple to me but the only problem is I can't find the menus or commands he's talking about in my version..his post was posted a few years ago with an older version.
Process - commands are the same.....
Create the reference plane (name it ALWAYS) and view that looks at it - goto the view - home tab set the work plane to the one you created
home tab - component - model in place ... void extrusion - sketch it and set its depth - set its category - finish the extrusion - set it to cut the wall - finish.
Why don't you just create a "Door" family with only the "opening" like you want?
Thank you so much *__* I was having the same problem.
To create an Arched opening in a Curved Wall |
Thu, Oct 28, 2010 at 3:53:07 PM
help with arched opening |
Mon, Dec 8, 2008 at 12:41:45 PM
Curved Wall |
Sun, Nov 13, 2011 at 10:56:42 AM
Arched Opening Problems |
Tue, Jan 18, 2005 at 11:06:11 PM
Compound Sweeps? |
Mon, Dec 18, 2006 at 10:00:03 PM
Members: | 1551763 | Objects: | 21383 | Forum Posts: | 151403 | Job Listings: | 3 |
