444 Users Online (40 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Revisions
Mon, Oct 23, 2006 at 9:14:01 PM | Revisions
jquiding
probabaly a simple answer but i'm a new user, i can't seem to get the revision box in the tiltleblock to match the latest revision when using the revision dialogue through the settings menu, any suggestions?
Tue, Oct 24, 2006 at 10:21:35 AM | RE: Revisions
TomDorner
4.5 Stars: 25 Votes
In order for revisions to appear in you titleblock, you will need to add a "revision schedule" to the titleblock. Check the Revit help menu for more information. Tom
Tue, Jun 5, 2007 at 1:22:04 PM | Revisions
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
Probably a little late to help the original poster, but thought I would add this in for future searchers:
It is my understanding that the revision box on each sheet only displays revisions that occur on that sheet. The revision box in the title block of your Cover Sheet is probably set up the same as your other sheets. It's not tracking the revisions for the set, it's tracking the revisions for itself. My workaround to get it to display all revisions is to squiggle a tiny revision cloud where it can't be seen (like in a filled bar) onto the Cover Sheet for each revision. That way, all revisions appear.
(Now back to my search for transferring all of the changes I just made in Revision #4 to Revision #5 because an outside engineer issued a change order with revisions that I forgot about.)
Edited on: Tue, Jun 5, 2007 at 1:23:39 PM
Edited on: Tue, Jun 5, 2007 at 1:23:52 PM
Tue, Jun 5, 2007 at 2:55:09 PM | Revisions
TomDorner
4.5 Stars: 25 Votes
Just FYI... revisions can be set to either be by project or by sheet.  Settings>Revisions and then choose the method you want.
Tom
Tue, Jun 5, 2007 at 3:55:35 PM | Revisions
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
True, that's good to keep in mind. We have it set to "By Project" to keep the numbers consistent throughout, but the revisions still only physically show in the schedule on each sheet depending on whether a revision has occured on that sheet. This is something that was set-up by someone else, so I am not sure of the intricacies involved enough to know if that is Revit standard (how other users will be experiencing it) or not. Sometimes this trips me up in my proposed solutions, since I am by no means an expert. Thanks.
Purging Revisions
Mon, Jul 10, 2017 at 9:30:49 AM
Multiple Updates of Revision by sheet at once - RAC 2010
Mon, Dec 21, 2009 at 3:15:29 PM
My revisions schedule won't go over 10 revisions
Wed, Oct 14, 2015 at 6:37:09 PM
2017- adding mutliple revisions to sheet index
Mon, Apr 15, 2019 at 3:29:19 PM
Revision Clouds Turn off/ Tag to stay on
Thu, Apr 8, 2010 at 5:36:46 PM
Page generation time: 0.1001
