77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> window schedule
Mon, Aug 22, 2016 at 6:04:25 PM | window schedule
integrity
I´m using revit 2016. Windows are not appearing in the schedule correctly or not at all. There are tags on the windows in the floor plan
and the correct mark in the properties dialog. What´s up
Carl
Mon, Aug 22, 2016 at 6:36:40 PM | window schedule
3.5 Stars: 388 Votes
You have not given us much to work on but here are some possibilities.
  • You created the windows in a phase different than your schedule.
  • You have a filter set in your schedule that excludes these windows.
  • These windows are not 'windows' but something else, possibly curtain walls.
The problem is something you have done.
Mon, Aug 22, 2016 at 9:03:42 PM | window schedule
integrity
The door schedule seems to work fine and was created the same as the window schedule, I think. The filters are set to
none. Could you expand on the meaning of phase. I´ve created other drawings in Revit without this problem so there must
be something I´m doing different!
Carl
Tue, Aug 23, 2016 at 7:08:03 AM | window schedule
marmiketin1
4.5 Stars: 10 Votes
Is the schedule set to show things in the 'EXISTING' phase and the windows were created in the 'NEW' phase. Phases allow for users to show different time periods of a building and when certain things happen (demolition, preconstruction, new construction and so forth. Check your help https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-DocumentPresent/files/GUID-2E104AB8-68B9-46F2-9BE2-B54E767429E5-htm.html
Tue, Aug 23, 2016 at 8:20:46 AM | window schedule
Doors and windows are different so they were not created the same.
You did not address the possible CW issue.  Curtain wall 'windows' are not Revit windows, they are curtain walls and are scheduled differently than windows although you can make a CW schedule that reads just like a window schedule.
Tue, Aug 23, 2016 at 11:23:48 AM | integrity
Bartholomew
5 Stars: 2 Votes
Quoting integrity from 2016-08-22 18:04:25
Carl
I'm curious to know what you mean by "Windows are not appearing in the schedule correctly." How exactly do they appear in the schedule?
Wed, Aug 24, 2016 at 8:21:51 AM | window schedule
integrity
These are not curtain walls but exterior structural. The phasing is existing. I drew a new wall on the plan with phasing
at existing and the window schedule at existing and the window did not appear in the schedule. It had a tag.
Wed, Aug 24, 2016 at 9:31:01 AM | window schedule
You don't seem to understand our answers.
  1. You say the walls are existing.   Are the windows also set to existing phase?
  2. What phase is your schedule set to?   It will only report that phase.
To clear this up, please post the following images:
  1. The plan showing the window and with the window picked, the properties of the window (Must show phase)
  2. The schedule with properties showing the phase
Thu, Aug 25, 2016 at 8:41:43 AM | window schedule
integrity
Here are the screen shots. The wall and the window are both new construction.
Thu, Aug 25, 2016 at 11:43:34 AM | window schedule
Did you know you should have a snipping tool that will allow you to just window and area of the screen to capture and image?   That works a lot better than the screen capture.
You did not show us the schedule and schedule properties - we need to see that.
Mon, Aug 29, 2016 at 7:58:40 PM | window schedule
#11
integrity
The snipping tool is new to me. Thanks.
Carl
Tue, Aug 30, 2016 at 6:32:05 AM | window schedule
#12
Now I am lost.
You wrote "...Windows are not appearing in the schedule correctly or not at all....".   Your window in plan is #81 and that clearly shows in your schedule.
Tue, Aug 30, 2016 at 2:02:19 PM | window schedule
#13
integrity
Yes. Some of the windows appear in the schedule. but windows 82-94 do not.
Tue, Aug 30, 2016 at 5:14:42 PM | window schedule
#14
We are trying to help and I asked you to post some images of the window and I assumed you would post the window that doesn't work.   Posting the window that does work doesn't show us the problem.
Tue, Aug 30, 2016 at 9:12:53 PM | window schedule
#15
integrity
Here is a picture of window 86 in the floor plan. Is this what you want? It is not in the window schedule.
LOOKING THROUGH THE WINDOW, SCHEDULE
Sun, Dec 19, 2004 at 7:03:39 PM
Window's dimension don't show up in the window schedule
Fri, Aug 17, 2012 at 1:34:43 PM
door in window schedule
Thu, Apr 29, 2010 at 7:47:41 AM
Window Schedule en Legends related to window MARKS
Tue, Sep 8, 2009 at 8:00:50 AM
Embedded window schedule in Room schedule
Thu, Nov 19, 2015 at 1:03:49 AM
Page generation time: 0.8447
