104 Users Online (103 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Leader Lines not attached to Coded Note
Tue, Feb 3, 2015 at 1:51:09 PM | Leader Lines not attached to Coded Note
mdlc516
Is there any way to eliminate the space between a coded note and it's leader line?  My boss started marking it up to make sure the leader line touches the coded note and I cannot figure it out.  Thanks!
Tue, Feb 3, 2015 at 1:51:49 PM | Leader Lines not attached to Coded Note
mdlc516
And yes, I just realized I used "Its" incorrectly Smile
Tue, Feb 3, 2015 at 2:20:47 PM | Leader Lines not attached to Coded Note
3.5 Stars: 389 Votes
Always take a look at the similar threads below .... like this one:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=10363
Tue, Feb 3, 2015 at 2:34:07 PM | Leader Lines not attached to Coded Note
mdlc516
Thanks for the link, but I spent almost an hour looking through the threads before posting in the forum and although I found leader lines with text questions, as the one you linked to, I did not see any referring to coded notes.  Therefore, I posted a question.
Tue, Feb 3, 2015 at 3:52:56 PM | Leader Lines not attached to Coded Note
I'm sorry, I should have been clearer.  The answer is the same.  Assuming you are using the correct text alignment (left justified for left leader, right for right), this space is hardwired in Revit and can not be controlled.  Your boss will not like the answer - live with it.
Tue, Feb 3, 2015 at 7:35:16 PM | Leader Lines not attached to Coded Note
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
With text object, try ‘leader/border offset’ in type properties. With keynotes, try ‘box size’ in type properties, even though you might not have a box.
Wed, Feb 4, 2015 at 6:46:32 AM | Leader Lines not attached to Coded Note
mdlc516
Thank you pijpiwo, that definitely helped with the text.  Unfortunately it doesn't look like the coded note has that option in the type properties.  But I appreciate your help.
Wed, Feb 4, 2015 at 9:24:47 AM | Leader Lines not attached to Coded Note
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Sorry, for some reason I thought you’re talking about the keynotes.
Can you post a family, so we can play with it? Are you using labels for your coded notes. Label’s leader can be kinda controlled. I know WW mentioned it’s hard wired, but I’m not 100% clear what you’re after. There might be a way or work around after all.
Wed, Feb 4, 2015 at 9:33:40 AM | Leader Lines not attached to Coded Note
mdlc516
Here you go.
Wed, Feb 4, 2015 at 9:35:25 AM | Leader Lines not attached to Coded Note
mdlc516
Here is an image of the issue.
Wed, Feb 4, 2015 at 10:17:06 AM | Leader Lines not attached to Coded Note
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
Hey mdlc516,
See attached, is this what you were wanting? If so what I did was change the 'Broken Section Display Style' from "Gapped" to "Continuous". See image.
To access this...
Go to Manage Tab > Additional Settings > Section Tags
Bear in mind the text makes the size of the tag change, which affects the leader line starting position.
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Wed, Feb 4, 2015 at 10:25:47 AM | Leader Lines not attached to Coded Note
mdlc516
Shatner86 unfortunately I can't open the file as it looks like you have a newer version iof revit than I do (I have 2013).  I did make the adjustment in the Manage Tab as you said and it didn't seem to change anything with my coded note.  Does my coded note qualify as a section tag even though it is an annotation?
I really appreciate your help on this.
Wed, Feb 4, 2015 at 10:52:02 AM | Leader Lines not attached to Coded Note
#13
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It doesn’t work with both number and note visible, but I’m guessing just a number will be displayed and the note will go to the schedule.
Edited on: Wed, Feb 4, 2015 at 10:52:46 AM
Wed, Feb 4, 2015 at 10:57:30 AM | Leader Lines not attached to Coded Note
#14
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
Hi mdlc516,
sadly you are working on the one revit version I don't have access to, I have 2012, 2014 and 2015... sigh.
Anyway, see the image attached? Is this what you were wanting?
If so, see the second image image. You need to place your circle on the centre of the insertion point. Then change your "Sheet Note"'s 'Vertical Alignment' to Middle. Then position your text so that it is centre (vertically I mean) onto the insertion point.
This will allow the leader line to remain in the correct location for the leader line if it is on the left. I'm not sure if it is possible to make it work in the other direction.
Kind Regards,
Shatner86
-Albert Einstein
Wed, Feb 4, 2015 at 11:16:06 AM | Leader Lines not attached to Coded Note
#15
mdlc516
Shatner86, that worked!  Thank you SO much!  The leader works from all sides.  Exactly what I'm looking for.
leader and coded note question
Thu, Nov 5, 2009 at 8:21:42 AM
leader lines
Mon, Jan 19, 2009 at 2:39:06 PM
Adding Snaps to Leader Lines
Thu, May 29, 2014 at 7:34:34 AM
Manipulating the Leader Line
Mon, Jan 2, 2012 at 11:05:14 AM
drawing a leader/arrowhead without text?
Mon, May 31, 2010 at 10:54:51 AM
Page generation time: 0.7467
